time to tackle the tensioner issue
Well, finished the tensiners, chains, and guides. Timing cover back on and should have the Dampener and other pulleys on today. Changed outh the oil pan (old one looks like she kissed the pavement pretty hard in the past) and transmission filter and gasket. Recieved my new steering rack as well and should have that installed today too. Will fill all fluids and crank it without the plugs in to get the oil circulating prior to "firing start".
I have the upgraded thermostat housing to install, but I need to get the old one off as well as xheck the hoses that travel under the manifold because there is a hissing sound and steam coming from under there the last time I started the car. I'm debating whether or not to take the manifold off so I can get a "birds eye view" of the cylinder head gaskets to make sure one has not failed. Upon cleaning and inspecting the spark plugs, 2 of the spark plugs had a little rust on the lock washers (not sure which bank they came from as I did not mark them).
Am I fogetting anything? If anyone has anything to add about anything I would love to hear it.
Thanks,
Bruce
Thanks,
Bruce
Thanks,
Bruce
Thanks,
Bruce
All the 'outside the block' stuff is just bolt on. I would equate tensioners with replacing rotors, calipers and brake pads. You will need a few less-than-common tools and good memory or pictures of how things came off but this is not rocket surgery . . . and you have the forum members standing by for responses within the hour.
Having a Harbor Freight store or on-line account will solve almost any tool issue very inexpensively.
no sweat
Was'nt that bad. Enjoying myself become at one with the car as well. Great learning experience for me so far and am enjoying doing it. I will say, I find myself looking for little things as well to make sure I have a good daily driver come this spring. Not sure if you know, but I bought this car at auction (sight unseen) and had it shipped from California to my home in Maine for a winter project. I've been wanting an XK8 Coupe for a long time and am thrilled with my progress so far and yes you can do anything you put your mind to......just takes a little homework and patience for the parts to come in.
Peace, Bruce
Peace, Bruce
Well, I finished the major work
Just wrapped up the engine work. Here's the recap........
The first picture is the front end stripped down.
The second is after replacement of tensioners and guides.
The third is after the timing cover has been installed and top end work started. I removed the intake and TB to get to the heater hoses and replaced the knock sensors while I was in there.
Fourth is the intake....I cleaned everything prior to reinstallation.
Fith picture is the finished product
With the repair manual, it's relatively simple to complete these jobs yourself. This site gives me the opportunity to get over the occasional bump in the road not specified in the manuals.
I also changed out the heater core which required removal of the steering column. I know I documented the process, but can't find the pictures on my or my wife's computers.
Going outside now to remove the windshield (which has a huge crack across it) so i can get to the headliner replacement project. (the headliner is literally "lining my head")
I don't mind chipping in if I am asked
Have a happy New Year!
Bruce
Bruce
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
Bcrary3
08-31-2015 11:29 AM
