Totally screwed my suspension; Need Help!
Old 05-09-2017, 04:52 PM
jobagadonuts's Avatar
Default Totally screwed my suspension; Need Help!
I'm in the process of replacing my upper and lower control arm bushings with Powerflex bushings and the uppers went in fine but the lowers were so tight I (regrettably ) used a floor jack to press the bushings into the subframe. I couldn't press the bushings far enough up now I can't get them out!
Any suggestions? I might try to melt it out as a last resort. After and stuck!
Before
Old 05-09-2017, 09:31 PM
Jandreu's Avatar
As in all things in life if you have to force it somethings not right! But my now I'm sure you have realized that. Do you have a little no crow bar? If so try getting the crow foot between the frame and control arm and use the leverage to pry them loose.
Old 05-09-2017, 10:08 PM
Johnken's Avatar
Received 1,808 Likes on 1,115 Posts
Don't forget to lube the hell out of it. Probably obvious but sometimes you can get so deep in a job you forget the little things. John
Old 05-09-2017, 10:37 PM
Ungn's Avatar
I had to use my dremel tool and blend/chamfer the edge where is was catching smooth.
And I was just trying to put the original bushings back. I can imagine new bushings would be tougher.
A heavy rubber mallet or plastic dead blow should knock everything into alignment or back out.
Old 05-09-2017, 10:54 PM
Roncarne's Avatar
I don't think the bushings are the problem, I think the sleeve in the middle of the bushings is what is hanging up......If you try to heat them or melt them, you may compound the problem, the fire danger notwithstanding. I suggest you get a "sawsall" with a metal cutting blade and cut the bushings right through the gut....it will be a sacrifice of the bushing but cheaper than damaging the lower strut or control arm....patience...don't just barrel in.
Old 05-09-2017, 10:57 PM
dsd's Avatar
dsd
dsd is offline
I've never done suspension work, how do these normally fit in? Is there a fitting tool or are they normally not that tight?
Trying to learn. Thanks!
dsd
Old 05-09-2017, 11:05 PM
Roncarne's Avatar
If you cannot get access to a "sawsall", an angle grinder with a thin cutting blade will work well. Use safety glasses.
Old 05-09-2017, 11:08 PM
Roncarne's Avatar
They are not usually that tight...tight but not to the extreme you have.....it will be fine if you "dry fit" new bushing sleeve prior to installation....some minor file work to the bush sleeve might be in order. Again, patience is the key.....you are not trying to break records, just learn, save money and be safe.
Old 05-10-2017, 07:03 AM
RaceDiagnostics's Avatar
A large pry bar between the arm and the subframe should get it out. Once you get it out check the bush sleeve length against the originals.
Fitting the arms with the new bushes was a very tight fit, it needed a trolley jack and bottle jack just to lever the two sides up (with both ends lubed with copper grease), then a lot of hammering to get the alignment perfect so that the bolts would go through unhindered.
The new bush metal inserts were the same length as the old ones, here is a comparison of new and old.
Test fitting to ensure the correct fitting of the thin and thick sides.
The total job took me about 8 hours for both sides.
The following 3 users liked this post by RaceDiagnostics:
jobagadonuts (05-12-2017), Johnken (05-10-2017), larueb (05-10-2017)
Old 05-10-2017, 09:18 AM
Johnken's Avatar
Ouch, if it took RD 8 hours, I figure it'll take me 20! But this will be a good reference for when I finally do..
Old 05-10-2017, 11:39 AM
Jandreu's Avatar
Note the "thin and thick" sides in RD's pic. Hard to tell but your pic's look like both sides are the same.
Edit, never mind just looked again and above comment is not relavent.
Old 05-11-2017, 09:08 AM
fmertz's Avatar
Received 1,487 Likes on 1,043 Posts
No, it's 4 days. You half the number (8/2=4) and you use the next unit of time (hours becomes days). Shade-tree mechanic's rule.
Old 05-11-2017, 03:41 PM
phanc60844's Avatar
I think you need to invest in some proper footwear before restarting this job, sandals are for the beach not the garage
Old 05-11-2017, 05:30 PM
frankc's Avatar
At a guess you have put the thick and thin sides in the wrong way around. Easy to do. I did mine in a friends garage with him, and he is a professional. Had a put the bushes in the wrong way. I did point it out to him but he said it would not make any difference.. 2 hours later he was using the garage lift to try and press the bush back out again and turn it around.
We all live and learn. Bet you wont do it wrong again but good on you for trying it yourself in the first place.
Old 05-12-2017, 05:09 PM
Thumbs up
Thank, this was the problem as you suggested: the metal tube in the center was offset as it was lifted in the sub-frame. It took two of us with large pry bars to finally get it out and re-installed. I'm bracing myself for the other side!
Old 05-12-2017, 05:15 PM
Thank you for the input and photos! The problem was exactly as you suggested; the metal tube was canted when raised into the frame. Took two grown men with large pry bars to remove them but it all went back in with both of us alternating raising both ends of the arm into place at the same time.
