Trans code P1748
Old Sep 17, 2020 | 12:06 PM
deelli's Avatar
Default Trans code P1748
Have 2002 XK8, had trans fault message...transmission seemed to be in limp mode (starting in what feel like 2nd gear). Found used transmission and installed...after installation, there was still trans fault message. Looked for codes (with regular reader), and did not see any codes, used a better reader and came up with the P1748 (pressure regulator). Didn't have good reader to check the trans that was removed, but the symptoms were exactly the same. My question is could the trans computer allow or cause this issue. Any help appreciated.
Old Sep 22, 2020 | 01:10 PM
I've deleted your other version of this post in Jaguar Engines & transmissions forum. The model forum is the best place for the question and discussion.
cafexjs
Sep 4, 2020 01:29 PM
metalmarty
Nov 3, 2014 06:42 PM
leestang66
Nov 4, 2009 10:47 AM
etreu
May 8, 2008 06:08 PM
