Trans fill plug??
Old Jan 28, 2025 | 03:33 PM
Herkey67's Avatar
Default Trans fill plug??
Hello all,
Well, things were going well with my trans sleeve kit install until I realized I hadn't removed the fill plug yet. Well, you guessed it, I stripped it out and are now going for the drill and extract method. Hopefully I will be done tomorrow with the help of many threads. My question is what do I need to order for parts. I searched for 2006 Jaguar Trans Fill Plug and nothing comes up. There are many drain plugs available, but I don't see a fill plug. Any suggestions?
Old Jan 28, 2025 | 04:28 PM
michaelh's Avatar
This thread may help if you haven't come across it:
https://www.jaguarforums.com/forum/x...1/#post1641362
The current Jaguar part # is C2C38965. It's available from the dealer if you have deep pockets:
https://parts.jaguarlandroverclassic...ller-plug.html
Some folks here mention the CTSC as being a good, helpful source of ZF parts and information.
It's in the ZF catalogue as a M18x1.5 'screw plug' with 8mm hex head. Unfortunately no part # is given.
The 6HP26 was used by a variety of manufacturers (BMW, Ford, Lincoln, etc.) so you may be able to source one from a breaker. Alternatively, I believe it's the same fill plug as the 5HP24 which does have a part # 0636 308 025
Torque figure is 35Nm
I would avoid drilling in case any shards escape into the internals.
Good luck!
Old Jan 29, 2025 | 01:04 AM
Y2KJag's Avatar
Originally Posted by Herkey67
Hello all,
Don't ask me how I know that you'll never make that mistake again.
Old Jan 29, 2025 | 01:50 AM
Pistnbroke's Avatar
So it dont happen to you or others I made a removal tool.....Take a 8 in length of 1/4 x 1 1/2 bar ( not critical) . Drill a hole near one end for the suitable hex key . and weld an inch of hex sticking out the hole.
Fit tool to gearbox plug and wack with a 4 lb hammer towards the front.
Old Feb 5, 2025 | 08:04 AM
Herkey67's Avatar
Default Job complete.
All is well. The plug has been replaced and the leaks from the trans are done. Shifts way smoother than before. Not sure what maniac decided that filling the trans through the side while the engine is running and with only a couple inches clearance from a hot exhaust pipe was a good idea, but the job is done. Thanks everyone for the help. Next stop, oil pan.
Old Feb 5, 2025 | 08:14 AM
michaelh's Avatar
Well done.
How did you remove the fill plug in the end?
placer61
Jul 16, 2021 09:25 AM
jagged77
Dec 26, 2018 12:21 AM
Ungn
Mar 11, 2018 03:43 PM
Fairfalcon
Jan 28, 2018 02:04 PM
Timspong
Nov 14, 2017 02:04 PM
