Trans fluid level check
Old Oct 12, 2014 | 03:11 PM
Redeye's Avatar
Default Trans fluid level check
Had the tranny fluid changed at last service. Only 34k on clock at time, but 11 years old, so seemed sensible. Prior to service no problems with gear change at all. 6 months down the line, Ive been getting the dreaded surging on warm up plus lumpy downshifts from 3rd to 1st.
Found out the Jag 'specialist' replaced the original fluid with Millermatic ATF at £5 per ltr, so am going to replace with ZF Lifeguard 6. Am hoping this will clear this issues! However, the question I really have is how much should drain out once I pull the drain plug? Im not sure if the right amount was filled at service, so by just replacing what comes out I could repeat an under or over fill. Will leave it overnight to drain but if it was filled correctly how much should drain from this procedure?
My plan is to drain, and assuming (say) 6 ltrs that comes out is correct, i'll replace with 6 ltrs, drive, drain again, then replace with another 6 ltrs.
Need to know how much trans fluid to order tho.
Jules
Old Oct 12, 2014 | 07:40 PM
RJ237's Avatar
I recall getting between 3 and 4 l. from a drain. It will take several changes to eliminate the existing fluid.
Old Oct 13, 2014 | 07:21 AM
Jon89's Avatar
Drained ZF ATF amounts seem to vary somewhat. Several forum members who have allowed their ZFs to drain overnight have reported more than 7 litres trickled out. When we drained my wife's 2006 XK8 in July 2013, we got right at 6 litres out of it....
Old Oct 13, 2014 | 04:34 PM
JagV8's Avatar
Refill properly, not by the amount that came out. For all you know the wrong amount was put in or some may have leaked out.
Plenty of people are using Millermatic without problems so you may be disappointed if you replace it.
Old Oct 14, 2014 | 04:06 PM
Redeye's Avatar
True. This isn't too expensive an option vs new TC or tranny, so gonna give it a go. Just seemed coincidental it all started after it was put in. Could just be the wrong level, so no harm in putting ZF back in and checking its right amount. Ordering 15 litres from Bristol Transmissions at £15.60 per ltr and hope this will be enough to do two complete drains and refills.
Old Oct 15, 2014 | 02:39 AM
JagV8's Avatar
15 should be plenty. Hope it works out. Remember to check level when it's fairly hot. A bit painful.
Old Oct 15, 2014 | 03:42 PM
Redeye's Avatar
Not looking forward to that. First time doing this!
aholbro1
Dec 29, 2024 06:46 PM
Bcrary3
Sep 12, 2021 05:41 AM
vsol
Aug 29, 2018 09:46 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
Numwen
Sep 6, 2015 12:30 AM
