Transmission issues
Old Oct 11, 2019 | 02:45 PM
Spinedoc2304's Avatar
Default Transmission issues
Hey Everyone
1997 XK8 Convertable. 158K. 35K on re-manufactured transmission.
So I had my transmission re-manufactured about 4 years ago and everything has been great up until about a month ago. In the morning, upon first startup, she slips in first gear for for about 10 seconds then gently engages or if I give it gas, I get the transmission fault warning. Rarely do I get any codes but when I do it's the "Stall speed" code (forget the # as I type this). There are no problems with reverse and this only happens after first startup. She is absolutely perfect the rest of the day. I shut her down when this happens, wait 10 seconds, restart and I'm good to go with no problems for the rest of the day.
Any ideas?
Thanks in advance
Nick
Old Oct 11, 2019 | 07:15 PM
RJ237's Avatar
Check the fluid level. If that's okay you may have a stored code that would help identify the problem. A shop capable of reading jag specific codes would probably be necessary.
Old Oct 14, 2019 | 03:44 PM
XK81997's Avatar
Hi.
I had a similar problem. But the cat only ran in 5th gear and limp home mode. There were 2 codes stored: P1722 and P0721.
P1722->Transmission oil level low, Selector cable adjustment / installation incorrect, Output speed sensor problem (Refer to P0721 Possible Causes), Transmission mechanical failure.
P0721-> Transmission to TCM output speed sensor circuit open circuit, short circuit or high resistance, Transmission to TCM output speed sensor circuit shielding defective, Transmission internal output speed sensor circuit open circuit, short circuit or high.
Maybe this helps.
larueb
Jun 1, 2015 07:05 PM
Callum Evans
Mar 17, 2013 04:08 PM
Peter Duffy
Nov 27, 2011 06:00 AM
iswan
Jun 23, 2011 10:19 PM
jimmycruz99xjr
Oct 5, 2010 08:17 PM
