Transmissions
Old Oct 15, 2015 | 04:35 PM
mrplow58's Avatar
Default Transmissions
What years had what transmissions in the XK8, and are all ZF5HP24 transmission valve bodies the same?....Thanks.....Mike
Old Oct 15, 2015 | 04:57 PM
test point's Avatar
The '97 through '02 used the 5hp24 transmission. The 'A' drum/valve body issue was known as early as '98. There have been lots of discussions on the subject but I have come to believe that sometime before '00 ZF had upgraded both the 'A' drum and valve body. At least they had by that time published acknowledgement of the problems.
I'll go see if I can find that technical document for a publish date.
Old Oct 15, 2015 | 07:08 PM
RJ237's Avatar
Tom is headed in the right direction, but it may not be easy to come up with a date. I thought I read something indicating a 01 to 02 fix for the main pressure valve.
One of the problems will be trying to nail down transmission serial numbers with chassis build dates, even worse than engine numbers with nikasil and tensioners.
Old Oct 15, 2015 | 08:19 PM
Gus's Avatar
Gus
See if this helps
Link.https://en.m.wikipedia.org/wiki/ZF_5HP_transmission
Gus
www.jagrepair.com
Old Feb 15, 2017 | 06:12 PM
JagMarc's Avatar
Default ZF 5HP24 Pressure Test Service Port
Does anyone know if there is a pressure test service port on the ZF 5HP24 trans and if so what should the pressure be in idle and in gear? 2000 Jag XJ8. Thanks!
Old Feb 15, 2017 | 06:33 PM
BobRoy's Avatar
I have the ZF repair manual and have done searches and couldn't find a way to check transmission oil pressure. Why are you checking the pressure, what is your problem?
Old Feb 15, 2017 | 08:31 PM
JagMarc's Avatar
Default Trans Pressure
Thanks BobRoy. I was helping user "Larney" redo the A drum and front pump in his garage over the last few weeks. I know everything will be fine once we put it back in and run it but was just curious for diagnostics reasons and just to double check everything once we get it back together. I thought there was some plug around the shifter linkage on the drivers side but its not really clear from any of the diagrams...
Old Feb 15, 2017 | 08:42 PM
BobRoy's Avatar
I think what you are talking about is a flow control valve. I wouldn't mess with it, it has a valve and a spring.
Good luck on getting it going.
Old Feb 15, 2017 | 10:17 PM
JagMarc's Avatar
I think that one from the pump housing is the volume control valve, yes I wouldn't want to mess with that one. I was thinking of number 8 in the attached picture. PH = line pressure, I think it has a removable plug there and I was wondering if that was the the line pressure test port.
Old Feb 16, 2017 | 06:21 AM
CorStevens's Avatar
Perhaps this will help. When I replaced the A-drum prior to failure as an insurance of sorts my tech told me that he was sure that my drum was of the type that can fail. It obviously differed from the replacement. He was also certain that my valve body was not affected by the earlier problems with over pressure. This is a 2001 car with the original transmission.
It is probably necessary to somehow get build dates for individual transmissions to learn their manufacturing dates. We have no idea how long the runs were and if a multi-year stock was produced. This would make sense from a manufacturing point of view with tooling considerations, etc. Stock was probably renewed every three years with additional replacement units allocated for warranty and replacement work. This means that a new car could have a transmission built three years earlier if not more.
Old Feb 16, 2017 | 11:19 AM
JagMarc's Avatar
We did replace the A drum with the newer beefed up type with lock in snap ring and did the new style kit on the valve body spring-piston pressure relieve valve. IF there is a service port on the trans I would like to visually check the internal pressure with a gauge just to see and verify how things are going on inside. Anyway, just wanted to see if anyone has done this before - check internal fluid pressure.
bostonjag
Mar 29, 2020 08:28 PM
n2audio
16
Apr 30, 2019 01:33 PM
scarbro2011
Oct 19, 2015 11:59 AM
XK8cat
Oct 10, 2015 05:04 PM
jjmiah217
Sep 28, 2015 09:09 AM
