Transponder programming for XK8 2002
Old Apr 7, 2021 | 08:46 AM
peter_190's Avatar
Default Transponder programming for XK8 2002
Hello all,
I'm going to upgrade my key to the one with integrated fob. So the questions I have are:
- which transponder is in the original key (XK8 07.2002)? As I know it should be ID13 or ID48 depending on the production year.
- is there a possibility to programm the new fob without any special tools?
Regards,
Peter
Old Apr 7, 2021 | 09:38 AM
fmertz's Avatar
You need the Megamos ID13. ID48 is 2003 and later. You will need specialty tools to program this in.
The fob can be programmed with no tools, check the stickies.
Remember, there is no "adding" a fob/key to the car. You have to program all keys or fobs in one session, up to (5) separate keys or fobs.
Old Apr 7, 2021 | 09:39 AM
RJ237's Avatar
The transponder is not programmed. The car is programmed to accept the key transponders.
Old Apr 8, 2021 | 02:10 AM
peter_190's Avatar
I was told the transponder ID13 can be easily clonned from one key into spare one. So the car settings are not necessary to be modified.
Regards,
Peter
Old Apr 8, 2021 | 10:06 AM
bcprice36's Avatar
peter_190,
You can remove the Transponder from one of the original Keys (by destroying it) and place it in the new (Flip-Key) and then you don't have to program anything! I did this a couple years ago and it works "Super-good"!...and then use the Key part as the Flip Key! You used to be able to buy the "Flip Key" without a Key for about $15.00 from eBay...This way you don't have to Program anything....
Billy Clyde @ Cinco Ranch .
Kyle Tice
May 21, 2017 09:38 PM
Lenny B
May 1, 2017 12:16 PM
CWMcGonigal
Nov 25, 2016 08:23 AM
duanelj
May 5, 2014 08:22 AM
StephanWolf
Nov 6, 2010 10:01 PM
