Which type front shock mount bushing?
Old Sep 29, 2014 | 03:03 PM
Dr. D's Avatar
Default Which type front shock mount bushing?
Howdy folks:
My foam ones have bit the dust. Having read some past post, I'm puzzled as whether to go urethane instead the foam. Any current experiences or recommendations appreciated. Normally, I would buy urethane, but in this case, I need some convincing one way or the other.
Many thanks.
Old Sep 29, 2014 | 03:57 PM
cjd777's Avatar
Dr. D, I have replaced standard ones with no problem, but let me say that looking at the mess the old ones were in coming out has me rethinking what the next one should be. I really believe the urethane will stand up much longer and the ones I took out were left too long, this resulted in the overall destruction of the polymer sponge. My only concern was the difference in the lower shock bushing taking too much of a beating with the different conpounds. I tried to find a bushing from Energy Suspensions with no luck, so until I find one, I still will go with standard.
I am still looking and have a old shock to try for a fitting.
Wayne
Old Sep 30, 2014 | 09:20 PM
Dr. D's Avatar
Wayne
Wayne:
I decided to play it safe this time and go with the foam. Maybe next time around we both will have a more decisive selection to choose from.
Old Oct 3, 2014 | 08:37 AM
XxSlowpokexX's Avatar
Is there a poly alternative?
Old Oct 3, 2014 | 09:55 AM
RaceDiagnostics's Avatar
Looks like there is an aftermarket version but I'm not sure what its made of.
Part search results from David Manners Ltd - MJA2170BD
Old Oct 3, 2014 | 12:05 PM
I hav eyet to tak emy suspension apart but it there a reason you couldnt use a poly material in tere? Is the foam made to squish? I know someone who makes poly bushings and could possibly make molds for these. Im just not 100% sure of the function yet
Old Jan 26, 2015 | 11:20 AM
SNG Barratt USA's Avatar
Former Sponsor
Not available in poly yet to my knowledge. We have them stocked as per original however...
SNG Barratt - The Ultimate Jaguar Parts Specialist
Front Upper Strut Shock Mount 1997 2006 Jaguar XK8 XKR MJA2170BD | eBay
Old Jan 26, 2015 | 03:41 PM
wolfpck1's Avatar
motorcars ltd sells a rebuild kit for the upper shock mounts the directions are not that good but if you look at the diagrams its pretty self explanatory . have had mine on now for almost 9 mos .
Old Jan 27, 2015 | 08:42 PM
robrtx's Avatar
Just looked at mine.........look pretty bad.
Any other wear items that could should be done at the same time as this?
Old Jan 28, 2015 | 05:00 AM
SteveJacks's Avatar
Upper control arm bushings, consider polyflex as a longer lasting and slightly more controlled, yet stiffer experience. I replaced mine with OEM bushings, didn't notice much difference in handling, particularly tramlining, then a few thousand miles later installed polyflex, made a noticeable difference, yet a very slight trade off to slightly harsher ride, barely noticeable in my opinion. Also, Shocks, or at least check lower shock bushing, at it is commonly worn item. The bushings can be expensive, and difficult to replace. New shocks are only slightly more than the bushings. As it turned out, after removal, I found that one of my shocks would not rebound, yet I beleived they were ok before starting the work. Also, check the steering rack boots while down there to be sure you don't have a torn boot.
Old Jun 16, 2015 | 10:38 AM
Back to the top:O) My car was sitting most all winter due to my lil fender bender and now that Im driving it...Well its developed some clunks. I ordered and received the complete Poly front bushing set and will also be In need of one wheel bearing...So Im doing all of the bushings and both bearings...Unsure which size I have! Saw there are two
Whiel Im at it what else should I replace? Ball joints? etc?
Thanks!
Old Jun 16, 2015 | 02:17 PM
Majik Lasers's Avatar
Where did you order the bushing set from? Link?
Old Jun 16, 2015 | 03:33 PM
Jaguar Performance Suspension Bushings
Came within a week. I bought the black race versions. Why? Don't know really!
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
rudelover2
Sep 11, 2015 08:53 PM
perfectphoto
Aug 30, 2015 01:15 PM
aquifer
Aug 29, 2015 04:54 PM
