unusual gearbox fault?
Old Jun 27, 2011 | 07:28 AM
Dlaregztif's Avatar
Default unusual gearbox fault?
I got into my 1998 XK8 on Saturday to go to town and suddenly the gearbox just went. The red light came on and 'gearbox fault' was shown on the display. It reversed back into my driveway with no difficulty but it would not move forward!
Last night I thought I would double check just to make sure it wasn't a bad dream and it was perfect, no light, drove perfectly for about 30 mins and again the light came on.
Anyone have any idea what the problem could be? The gearbox isn't making any unusual noises and therre was no signs of a problem building up.
Thanks in advance!
Chris
Old Jun 27, 2011 | 07:57 AM
Andy94SC's Avatar
Try to read the codes before you do anything more with it.
Old Jul 11, 2011 | 02:16 PM
Dlaregztif's Avatar
I finally got around to checking the codes, it read P1722. Does it sound like a mechanical or electrical problem??
Old Jul 11, 2011 | 06:44 PM
H20boy's Avatar
found these in a quick search for P1722 in this forum...
https://www.jaguarforums.com/forum/x...ighlight=p1722
sounds mechanical my friend!
Old Feb 23, 2012 | 05:03 PM
Dlaregztif's Avatar
forgot all about this post!
update: the A clutch pack failed, new gearbox fitted
there was 135k miles on it so knocked a good bit of use out of it, especially considering its my everyday car!
Old Feb 25, 2012 | 11:52 PM
H20boy's Avatar
better late than never at least!
Old Feb 26, 2012 | 06:00 AM
dennisw's Avatar
scarey..bet it cost big time
Old Feb 27, 2012 | 04:08 AM
Dlaregztif's Avatar
it cost a bit but not as much as I expected. I did most of the work myself with my father. The only problem was the transmission oil. Jaguar Ireland were looking for $800 for 6L of oil but got it eventually from a supplier for $240 for 20L. In total I spent $1000 but a lot of time fitting due to all the original bolts being seized and taking forever to remove
Old Feb 27, 2012 | 05:25 AM
I thought the ZF capacity was around 10 litres - is this Esso ATF LT 71141 liquid gold just available in 1 litre or 20 litre packs?
Old Feb 27, 2012 | 07:48 AM
Reverend Sam's Avatar
I don't want to start a huge transmission fluid debate, but I see no reason to use the $800 Jaguar fluid, unless maybe you are just trying to keep Jaguar from going out of business. There are lots of threads on here about alternative fluids that cost just a few dollars per liter and meet all of the same specs.
Old Feb 27, 2012 | 08:22 AM
The Coupe's Avatar
The proper ZF fluid can be found at much cheaper pricing...you just have to know where to look.
The CTSC - California Transmission Supply Company...sells our ZF fluids for about $ 16 a quart. You buy from them...the fluid is shipped to you directly from ZF. At least that's how they shipped to me last week.
Here's the link: The CTSC - ZF Transmission Fluids
Good luck.
Old Feb 28, 2012 | 04:35 AM
Dlaregztif's Avatar
I searched this entire island for the fluid and could only get it from two places, Jaguar Ireland or a lubricant supplier. It was available from Jaguar in a 1L and 5L and the independent supplier had 20L only. I priced alternative fluid but worked out slightly more expensive!
JaguarLover101
48
Jun 12, 2023 10:28 AM
3lvis
Oct 1, 2015 01:56 PM
RedRider48
Oct 1, 2015 08:18 AM
jjmiah217
Sep 28, 2015 09:09 AM
