upper control arm bushings
Old Jun 24, 2020 | 04:03 PM
sknight751's Avatar
Default upper control arm bushings
I have a 2006 XKR (X100) that needs upper control arm bushings. My local garage says each control arm requires two bushings for a total of 4. They say the bushings are $120 ea. And, the pin that goes through them (2 needed) are $140 ea.
Does anyone know of a supplier that has these parts for less money?
Steve
Old Jun 24, 2020 | 04:36 PM
Johnken's Avatar
That's a crazy high price! Check power flex https://www.powerflexusa.com/shop/ca...1996-2006-1451
You can get all 4 for the price of 1. Yes its polyurethane, no it doesn't squeak, rougher ride? No
Old Jun 24, 2020 | 04:39 PM
Johnken's Avatar
BTW it's a relatively easy job, you can do it without special tools. Some found removing the upper bolt easier than others, that's the tough part if anything is.
John
Old Jun 24, 2020 | 05:56 PM
STLTHMSTA's Avatar
OMG, where the hexx is he getting those parts?? That's a hexx of a mark up. Take the car somewhere else or do it yourself.
$20 each from rock auto.com. I just did the entire front suspension on mine and the uppers were the easiest part. TM
Old Jun 25, 2020 | 12:52 AM
DavidYau's Avatar
Default Rip off prices
Geez! Those are more than Dealer level charge out costs!
Better PU after market parts now available (Powerflex etc) and you just need to clean and polish the existing bolt.
Did it DIY as part of my recent complete suspension R&R albeit with some difficulties.
Old Jun 25, 2020 | 03:22 AM
PKWise's Avatar
sknight751,
Yeah that is a total rip-off price. Powerflex poly bushes are $125 on ebay for set of four!
Are you sure you need new pins? They usually clean up pretty good. See mine before and after.
Old Jun 25, 2020 | 09:37 AM
STLTHMSTA's Avatar
'Nough said right there. Just 'cause it's a Jag doesn't mean the prices have to go through the roof. I'm kinda wishing I bought the Powerflexs but it's done and I will never need to do them again. On to other areas.
Old Jun 25, 2020 | 09:39 AM
JayJagJay's Avatar
Steve
Hey Steve...
As everyone has said, and are rightfully shocked, the parts can be had for much much less.
If you need the pin (and that's an if for 2 reasons, one, the mechanic would have a very differcult time knowing the condition of the pin in situ and 2, the hole in the subframe that the pin rides in, aluminum, often will wear before the steel pin) one can be found on a site called British Parts and shipped, which can be given to any mechanic to do the work for you. Supply the parts, pin and bushings, to the mechanic.
Are you interested in doing the install yourself?
Old Jun 25, 2020 | 06:47 PM
michaelh's Avatar
If those are 'to supply & fit' prices, then maybe OK. Otherwise, someone is 'avin a larf'.
OEM (Heritage) prices are around $40 for the bush (MJA1462AB) and $48 for the fulcrum bolt (MJA1455AD) which, as others have said, you may not need.
Old Jun 28, 2020 | 11:43 AM
Jaaagtime's Avatar
Like others mentioned easy job and much cheaper, I just did this and I got them from Moss motors, rockauto also has them they are around $20 each and its confusing how they word it on their site but you need 4 pieces they are the URO brand so not OE but good enough for a few years
NEO Cat
Jan 1, 2017 04:41 PM
daboss085
Jul 29, 2013 01:52 PM
Gus
Nov 26, 2012 03:11 PM
eastsidejp
16
Dec 22, 2010 07:17 PM
