VVT on my 1997 XK8
Old Sep 23, 2021 | 11:33 PM
Dennis Reardon's Avatar
Default VVT on my 1997 XK8
Do all XK8's have variable valve timing or is this an optional engine accessory? How do I tell if I do (or don't) have it?
Thanks,
Dennis
Old Sep 24, 2021 | 01:48 AM
Pistnbroke's Avatar
They all do . I had the cam cover off mine yesterday and its there . You will see a connector at the front of each bank which controls it/them
Old Sep 24, 2021 | 08:37 AM
motorcarman's Avatar
AJ26 uses TWO STAGE VVT units (retard and advance) and the AJ27 uses CONTINUOUSLY VARIABLE VVT units.
Old Sep 24, 2021 | 09:55 AM
Pistnbroke,
Thanks for the reply. Are these electrically controlled or oil pressure controlled?
Thanks,
Dennis
Old Sep 24, 2021 | 09:58 AM
Motorcarman,
Thanks for the info. How do I tell which engine I have? Is it by year or some other identifier?
Thanks,
Dennis
Old Sep 25, 2021 | 08:30 PM
Markel's Avatar
Originally Posted by Dennis Reardon
Motorcarman,
Thanks,
Dennis
l believe the quick and easy way is ;
Coils 2 wire AJ26, 4 wire AJ27
AJ26 has large vacuum canister for the CC by throttle body AJ27 does not
Old Sep 26, 2021 | 01:05 AM
Pistnbroke's Avatar
and "CC" stands for ?
Old Sep 26, 2021 | 07:05 AM
BobRoy's Avatar
Motorcarman,
Thanks,
Dennis
If you have a 97 you should have an AJ26. The VVT will be in the timing cover. On the AJ27 the VVT is in the cam cover.
Old Sep 27, 2021 | 03:19 AM
drmike's Avatar
Cruise control
Old Sep 27, 2021 | 03:23 AM
Pistnbroke's Avatar
No CC on my 97 so no canister ..thanks for clarifying that
Old Sep 27, 2021 | 10:40 AM
BobRoy,
Dennis
Old Sep 27, 2021 | 11:28 AM
xalty's Avatar
are you sure 🧐 take a picture of your throttle body.
that would be an ultra rare part that belongs in a museum
Feral XK8
Aug 20, 2021 09:56 AM
Potvinguy
Apr 9, 2020 03:33 PM
jbonilla
Nov 7, 2017 08:41 AM
avt007
Aug 31, 2013 01:14 AM
