Welch shock mounts vs Jaguar OEM
Old Apr 28, 2021 | 03:24 PM
zray's Avatar
Default Welch shock mounts vs Jaguar OEM
Ignoring any cost differences, are these two options now equal in theoretical longevity. Or are the newish, and apparently diminished, Welch mounts still better than Jaguar OEM ?
My mounts, shocks, and associated bushings were replaced by a previous owner @ approximately 114,000 miles. Now another 52,000 additional miles have been racked up. Judging by ride quality, ride height and visual inspection the upper mounts are still in remarkably good condition.
However. I know this state of grace won’t last forever. I’m aware of the ongoing efforts by forum members to manufacture a quality replacement, but for now I’d just like to have opinions on which product is going to last the longest, the Welch, or the OEM.
Z
Old Apr 28, 2021 | 05:23 PM
giandanielxk8's Avatar
In my personal experience driving on the surface of the moon, aka, Puertorican roads, the Welsh mounts are lasting about 11 months on average. The OE mount pancaked flat after about 10 years. I never tried aftermarket OEM-style mounts. My experience may be an outlier given the state of the roads in PR. However, recent adopters of the Welsh mounts are seeing their mounts fail just a few months after the warranty expires. Welsh seems content to leave it as-is instead of responding to the issue as their customers shed light on it for them. If they have the arrogance to believe they have the market monopoly on "upgraded mounts" even after they dropped the quality of their products, they are in for a shock once a better product appears. Word is already spreading about how the quality of their product has dropped and how they have treated customers who reach out to them.
Old Apr 28, 2021 | 05:27 PM
zray's Avatar
I am leaning toward the genuine Jaguar mounts (OEM), as those currently in the car (genuine Jaguar parts) have lasted / are lasting a good long while.
Z
Old Apr 28, 2021 | 08:10 PM
rothwell's Avatar
Below is my reasoning from an earlier discussion on this.
Originally Posted by rothwell
Well I have replaced two sets of uro foam and one set of welsh poly so far...
The reason that I will reluctantly continue to use the Welsh is because even though they fail too soon it is the inner bushing that seems to fail which is opposite of the foam mounts where the outers tend to collapse first. So with Welsh I will get shock clunks and will know to replace them well before alignment is affected. The others will just collapse and can ruin your tires before you can likely catch it due to adverse alignment with no noise until the very worst point when the metal starts rubbing together.
I have stated before that I think the sweet spot is a welsh outer bushing with a stock inner bushing.
With the OEM part being about 3X the price of Welsh/URO for me that is a deal breaker. I would rather risk replacing them more often than spending that much up front in hopes they last 3X longer than the non-EOM.
I have replaced them 3 times so far over 70K miles and 7 years. Getting pretty good at it now.
Old Apr 29, 2021 | 06:20 AM
cjd777's Avatar
Zray, go to thread #93 in my little efforts on the top shock mount and you will see the problem with Welsh.
The inner bushings were the consistency of melted tar and they had been out of the car for a long time.
Couple of other problems but you get the picture.
Old Apr 29, 2021 | 06:41 AM
Jon89's Avatar
At this point I would not install either current OEM or current Welsh. OEM is both materially flawed and ridiculously overpriced, while Welsh's quality control has nosedived yet they continue to ignore it. Wayne's product should resolve this issue for all of us....
Old Apr 29, 2021 | 09:15 AM
wymjym's Avatar
My original, from the original build, mounts lasted until 135K.
I have installed welsh units and plan on purchasing a set or two of Wayne's when he has them finished. When I install new shocks I'll pull the welsh units and sent them to wayne as their housing are useful.
If it was a choice between welsh and Jag oem I would go with Jag oem. I enjoy working on the car but not continually replacing the same items in short order.
wj
Old Apr 29, 2021 | 11:20 AM
zray's Avatar
That would be a great solution, if my current Jag mounts can continue to hold up until Wayne’s product is available.
However they are on a daily driver with over 50,000 miles on them. After reading many postings relating the failures of this part, I suspect I’m driving on borrowed time.
Z
Old Apr 29, 2021 | 12:08 PM
rothwell's Avatar
Z
I suspect that road conditions are a major factor toward longevity. All it takes is one errant pothole or speedbump to ruin them.
Pretty sure that is what happened to me with my last set of Welsh ones. They just can't handle severe impacts and the center bushings fail.
Old Apr 29, 2021 | 12:53 PM
Lannyl81's Avatar
How do I find-out about Wayne's product? Appears I am in need of replacing the Welsh mounts....again....
Old Apr 29, 2021 | 09:15 PM
It's the thread titled "Top Shock Tower Issue".
David Dougherty
Nov 17, 2020 03:38 PM
Brettl
Jul 15, 2020 07:04 PM
stevepaa
Oct 1, 2019 12:16 PM
David Dougherty
Nov 13, 2017 11:34 AM
RJ237
Mar 16, 2014 11:10 AM
