The "What did you work on today" thread.
Old Dec 18, 2021 | 04:43 AM
  #1001
drmike's Avatar
I can't quite recall but I did manage to touch the top of the pump I'm sure to feel if it was running. If my pump was broken (and thankfully it wasn't) I was going to do what that guy in the link did. I thought removing the pump from the top was very hard and I don't have access to a lift.
Old Dec 18, 2021 | 04:53 AM
  #1002
Pistnbroke's Avatar
I can get it up but the weather is against me and I have an owner from Texas on his way to see me so want to drive the car to investigate the grinding from the torque converter area.
Old Dec 18, 2021 | 05:04 AM
  #1003
drmike's Avatar
Tell me about the weather, I'm not so far from you (well 30 miles) and today is dank. The Texan is the guy who asked about batteries and stuff?
I'm sure he's hardy enough not to need a heater
Grinding noises though - not so great.
Old Dec 18, 2021 | 05:06 AM
  #1004
Pistnbroke's Avatar
He was born in Rugby where I live so coming to see his mum.
Old Dec 18, 2021 | 05:28 AM
  #1005
drmike's Avatar
Nice. I bet doesn't bring his battery though.
Old Jan 8, 2022 | 06:04 PM
  #1006
crbass's Avatar
Default Long Jobs
Bad news: About three weeks ago, I washed the car, polished the hood and snoot in preparation for ceramic coating the hood/snoot that had to be repainted in the fall after a surprise encounter with an itinerant box spring at high speed on the interstate.
Good news: All six of us in the house are now over COVID, and the two hour job was completed this evening. Hooray.
Temporary pinstripes make the hood 'pop'.
Old Jan 9, 2022 | 06:01 AM
  #1007
Jon89's Avatar
Well done, and glad to hear that your household's bout with Covid is now behind you. I hope the symptoms remained mild for all of you. It is indeed running rampant around here....
Old Jan 9, 2022 | 05:43 PM
  #1008
AFTERSHOCK's Avatar
Default New radiator installed today
I finally got a little spare time and installed my new radiator that was sitting in my garage for the last 6 months. Lol the car would only leak antifreeze on start up, about an once or 2 and stop, and sometimes it would not leak, hence why I procrastinated for so long. Lol install was pretty straight forward only had issues separating passenger side condenser was way easier to install the new one then take the old one out. Was about 2 or 3 hours total. Hooray
Old 23 year old radiator, hope the new ones lasts at least half that time.
Old Jan 9, 2022 | 07:02 PM
  #1009
szhilian39's Avatar
Did some cleaning. Removed the old stinky sponge under the rear seat and replaced it with some new materials.
Also, did some color restoration job.... seat belt buckle.
Old Jan 11, 2022 | 04:35 PM
  #1010
szhilian39's Avatar
Before...
After...
Old Jan 11, 2022 | 05:12 PM
  #1011
dfbender's Avatar
Originally Posted by szhilian39
Before...
After...
What did you use to clean it?
Old Jan 11, 2022 | 06:13 PM
  #1012
szhilian39's Avatar
I used this, combined with a steamer, toothbrush, and microfiber towels.
Old Jan 11, 2022 | 06:33 PM
  #1013
AFTERSHOCK's Avatar
great job and what a difference. Wow
Old Jan 12, 2022 | 03:31 PM
  #1014
fmertz's Avatar
Originally Posted by AFTERSHOCK
FWIW, the parts store generally carries an assortment box of coolant plugs suitable to cap this bleed nipple. I had a home-made contraption like that for a while and it eventually started leaking. Because of course it did.
Old Jan 12, 2022 | 04:10 PM
  #1015
AFTERSHOCK's Avatar
I actually work at a hardware store Lol. The plug is a aqua pex plug for 1/2 pex line. It was the best solution I could come up with that we had. I will keep an eye on it now that you mention it though.
Old Jan 13, 2022 | 02:21 PM
  #1016
szhilian39's Avatar
Default Belt Trim Pin Fixed
I was using JB Weld and a piece of credit card. Now, the trim is firmly fixed without making any noise.
Old Jan 22, 2022 | 04:34 PM
  #1017
tsuppari's Avatar
Working with brittle cupholder hinge second time. First fix lasted two year. Now 'final metal solution'. Incredible brittle plastic; like flour after 20yrs.
Soldered piece of nickel/copper tube to 1mm metal sheet as a new hinge point.
Then epoxied it into cupholder. Now holder will last here and cupholder will break some other point
Old Jan 26, 2022 | 12:38 PM
  #1018
Flcat's Avatar
Default 2002 XK8 engine light
Hi I cleared an engine light today. The code was PO442, Evaporative Emission System leak detected. (small leak). Anyone have an idea for this DIY. Ty
Old Jan 28, 2022 | 08:14 AM
  #1019
NorXKR's Avatar
Could be the fuel filler cap that is not air tight anymore. It is the easiest thing to try first.
Old Jan 28, 2022 | 01:57 PM
  #1020
szhilian39's Avatar
Before...
After with a custom-made cup...
