what do connectors on these parts do?
Old Feb 18, 2019 | 08:20 PM
engravosaurus's Avatar
Default what do connectors on these parts do?
LJA6190AC and MJA49490AG both include connectors/switches
I would like to know what these connectors do, what do they connect to but
My search has failed, am stumped
Anyone know how to find out what these connectors/switches do? or know where I can find it?
thanks
Old Feb 18, 2019 | 08:27 PM
Gus's Avatar
Gus
The first switch is located under the shifter if I am correct.
Link 1997 wiring diagram http://jagrepair.com/images/AutoRepa.../jagxk1997.pdf
Old Feb 18, 2019 | 09:37 PM
thanks, helpful
still need to know "name" of each switch/connector
Old Feb 18, 2019 | 11:00 PM
flatsix's Avatar
The first one is a shifter switch, located at the j-gate. the switch simply signals wether a gear is engaged or if the shifter is in park position. The second number must be wrong, no matches on google.
Old Feb 19, 2019 | 11:01 AM
thanks
the numbers have apparently evolved
LJA6190AC used to be JLM20304
MJA4940AG was MJA4940AF and before that MJA4940AE
maybe an older # will appear in google
Old Feb 19, 2019 | 12:45 PM
flatsix's Avatar
MJA4940AF is a mounting plate for the linear switch, located left beside the j-gate assembly. The mounting plate has two micro switches, in connection with the linear switch the transmisson controller gets information of the shifter position.
Old Feb 19, 2019 | 04:24 PM
Hi and thanks
so then on the pic above are the part numbers assigned correctly?
and
where on google do you find this stuff?
thanks
Old Feb 19, 2019 | 10:25 PM
flatsix's Avatar
Hi, yes seems to be right and you will find the parts on Jaguar Classic Parts for instance.
Old Mar 4, 2019 | 01:22 PM
Thanks. Continue fiddling with this.
I have 3 problems
1) doors don't lock when moved from Park as manual says they should and
2) memory buttons work when in R or D as manual says they should not
3) and there is a click under the J-gate when stepping on the brake when not in Park as if car saying ok to move from park
so I keep researching not-in-park switch and the Body Processor Module
query
do these events generate fault codes that can be read with proper equipment?
Old May 17, 2019 | 07:13 PM
Hi
Still struggling with this; sorry
MJA4940AG and LJA6190AC show up at
https://www.jaguarclassicparts.com/u...trol-automatic
items # 4 and 23; VIN xxx02000
would like to know what each of them actually do?
could failure of either cause drive away door locking to fail?
thanks
Old Aug 4, 2019 | 04:27 PM
well I did the "pay 'em to find it" method
and shop found a faulty park neutral switch
drive away lock has worked fine for two months
cyber3d
Feb 24, 2019 09:53 PM
AndyD115
Dec 18, 2016 01:14 AM
sjc1997xj6
Mar 26, 2014 12:24 PM
M6XKR
Feb 26, 2014 07:52 AM
cincinnati
Apr 8, 2010 02:55 PM
