What is this long piece on an XK8 called?
Old Aug 22, 2013 | 11:38 PM
Windycityx's Avatar
Default What is this long piece on an XK8 called?
I actually found them on Ebay... how hard of a job and what is needed to replace this long chrome horizontal bar, in between the two vertical splitters? Mine is cracked.
Old Aug 23, 2013 | 12:56 AM
eieio's Avatar
I heard someone call it a "wing" once.
Old Aug 23, 2013 | 02:48 AM
It's called a SPLITTER VANE - Part Number HJA6451BC for your MY. See item 10:
To remove and replace it without damage, the Front Bumper has to come off. Then remove the four rivets securing the gray plastic Overrider covers to beam and remove covers.
Remove the three rivets securing the Splitter Vane to the to underside of bumper beam.
Often the Splitter Vane and Overriders are just broken of without removing the Front Bumper when fitting a mesh grille.
Old Aug 23, 2013 | 06:29 AM
philhef's Avatar
I have one I was going to,list on ebay myself. Off my 2002. It's in perfect shape.
Was going to list for 20.00 plus 10 shipping.
Let me know If interested.
Old Aug 23, 2013 | 08:59 AM
Norm 427's Avatar
I just replaced mine. Just remove the 4 plastic doo-dads (on top of the overriders accessed via the hood up) that hold the 2 dark gray overriders in place and pull then out front ... then unscrew the chrome horizontal splitter ... it's easy as eating apple pie. Took me less than 30 minutes.
Old Aug 23, 2013 | 11:05 AM
Windycityx's Avatar
Without removing the front bumper?
Old Aug 23, 2013 | 11:06 AM
Windycityx's Avatar
Does anyone know for sure if this will fit a 97?
Any damage? As long as it fits, I will take it! Thanks!
PM sent
Old Aug 24, 2013 | 06:07 AM
philhef's Avatar
My over riders were cracked so I actually broke them off but they're only held on by a couple plastic fasteners. You can feel their rounded head where they attach to the metal inner bumper. They can be pulled out with a flat head screw pushed under and worked out.
BUT! The aluminum overriders underneath don't come off so easily. They at riveted on. I cut mine off while front bumper was being worked on.
To replace the chrome bar, the plastic over riders have to be removed since it goes behind them, then replaced.
Old Aug 24, 2013 | 07:25 AM
Norm 427's Avatar
Correct. No need to remove the front bumper. Schedule 30 minutes for the job, 45 minutes max.
Old Aug 24, 2013 | 09:29 AM
Windycityx's Avatar
So would I need new overriders or can I use the ones that are already on my car?
Old Aug 24, 2013 | 12:51 PM
Norm 427's Avatar
You can reuse your overriders if they're not hopelessly damaged.
I didn't have to remove anything that was riveted ... for me it was just 4 little plastic doo-dads holding the top of the overriders in place and a couple of screws on the bottom side of the horizontal chrome bar.
Old Aug 25, 2013 | 10:08 PM
Windycityx's Avatar
Does anyone know if Philhef's chrome bar off of his 2002 XK8 will fit on my 97?
Old Aug 27, 2013 | 04:00 PM
70z28's Avatar
Hi I have 1 off a 97 if the other guy doesnt get back to you iam breaking a full car if you need anything els
Old Aug 27, 2013 | 06:09 PM
The Splitter Vane part numbers are:
HJA6451BC from the first XK8 up to VIN A11050
HJA6451AB from A11051 to A40264
C2N2745 from A40265 to end
If philhef's VIN is below A11050, it will definitely fit.
Old Aug 30, 2013 | 11:25 AM
Windycityx's Avatar
I am still looking for this piece ( SPLITTER VANE - Part Number HJA6451BC )
Philhef or 70z28 let me know if I can buy one yours, or anyone else!
Thanks!
( one fog light also needed )
Old Sep 2, 2013 | 04:00 PM
Windycityx's Avatar
Hey does anyone have one of these available for sale? I would rather not overpay on Ebay if I don't have to, thanks
Old Sep 3, 2013 | 06:33 AM
philhef's Avatar
Have you thought about a total upgrade? And still factory!
Old Sep 6, 2013 | 01:54 PM
Windycityx's Avatar
I want to keep this particular car with the 100% stock look. My other one has the black mesh one piece grill, spoiler, exhaust, tinted taillights, chrome 20" wheels etc.
Anyone know where I can find one besides Ebay?
Old Sep 13, 2013 | 09:17 PM
Windycityx's Avatar
I found one off of a 2001 XK8 he said this is par of is vin, will this fit my car or is it not the right part of the vin?
VIN from the car with the part for sale: sajoa42c81na
This was post earlier:
Old Sep 13, 2013 | 09:25 PM
Jag#4's Avatar
If not mistaken, I think you are missing part of the VIN. It's the numbers after the NA you want.
