Will it pass emission test?
Old Aug 27, 2018 | 08:08 AM
Rodkel's Avatar
Default Will it pass emission test?
99 xk8 .Replaced fuel pump.cel is off but pending po171 still on. Will it pass inspection? If it fails, how do I clear the pending code?
Old Aug 27, 2018 | 09:23 AM
avern1's Avatar
You info doesn't give the state you live in and there are different requirements by state. The odds are against you for passing smog with a pending P0171 code. The ode indicates you are running lean on the right bank. I have attached a copy of the DTC definition for the P0171. Since it is a pending you most likely have a small vacuum leak causing the code to flag.
Old Aug 27, 2018 | 01:29 PM
JagV8's Avatar
Many areas check the OBD monitors are set so why not find what you're allowed and read yours?
BTW every code clear also clears ALL of the monitors.
calvindoesntknow
Sep 21, 2013 04:58 PM
PaulB
Aug 9, 2013 08:33 PM
MRomanik
Sep 9, 2012 06:10 PM
yuannyh
Aug 2, 2011 05:01 PM
King
Aug 26, 2010 11:59 AM
