Wind Deflector
Old Jul 13, 2020 | 03:36 PM
kevh's Avatar
Default Wind Deflector
Hi All,
I have just bought a 2003 XKR convertible which has a wind deflector with it, it is the one in the photograph below with arms which fit into the slots in the car body and the horizontal part has tabs which tuck behind the rear seats. Questions are; is this the original one which would have been bought with the car? and how far into the slots should the arms go? when pushed in as far as they will comfortably go there is about half of arm still showing and it looks to me like they should go in further.
I hope that makes sense.
Old Jul 14, 2020 | 03:11 PM
Redline's Avatar
Kevh, Someone may correct me but I believe that all the wind deflectors for the XK8/XKR are "after-market." The convertibles only came with a removable factory cover for the top itself. There are 3 or 4 offerings for wind deflectors, all with unique attachment points; the one I purchased for my 2005 XK8 looks just like yours. I actually had to cut one rear seat tab and spot weld it back together to get the right spacing on one side. The best you can do is adjust the wind deflector to prevent the most wind possible from going down into the back seat (and up your arm and neck...), but it is great in actual use and also helps to hide anything left in the back seat.
Old Jul 15, 2020 | 12:44 AM
kevh's Avatar
Thanks Redline, if your deflector is the same can I ask how much of the arm is visible when inserted, I have a gap of maybe 1.1/2" between the top of the seat and the bottom of the deflector which I don't like, the arms on mine have notches which look like they should possibly click into place but they don't want to go in far enough.
Old Jul 15, 2020 | 09:40 PM
Redline's Avatar
Here's how my deflector is mounted. It would be helpful if you could add some pics of your installation; perhaps there are some options...
Old Jul 16, 2020 | 07:52 AM
SamtheSham's Avatar
Did you have to pull the rear seat sides to get to the mounting point??
Old Jul 16, 2020 | 10:58 AM
Redline's Avatar
The rear tabs of this Airax wind deflector from Windshott just slide right between the seat and the "armrest" in the back and rest on top of the sidewall; no disassembly required. Only the front is attached via a quick release (requires drilling of a small hole on each side, just behind the seatbelt attachment). Do these pics help?
Old Jul 16, 2020 | 11:00 AM
SamtheSham's Avatar
Yes, Thx.
Old Feb 16, 2021 | 11:48 PM
Hazmat1075's Avatar
Hello. I hope you are still enjoying your XK8. Q: does the wind deflector prevents having your hats blown off. Would you recommend. I just bought a 2005 XK8 and love it. However, wearing hats with the top down is an issue
Old Feb 17, 2021 | 01:27 AM
Redline's Avatar
The wind deflector helps to block air blowing in from behind you, (both around your head and also around the seats, brrrrr), so yes, it's quite effective in lowering turbulence inside the cabin. I won't own a convertible without one. Now, all bets are off if you are wearing a very tall hat or you catch a side wind, but with a side wind you can at least raise the two door windows and get a very comfy cabin again!
Old Feb 17, 2021 | 11:34 AM
Hazmat1075's Avatar
Thank you for you prompt reply. I'm trying to convince my wife into getting one..
Old Feb 17, 2021 | 01:06 PM
kevh's Avatar
The wind deflector transforms the driving experience in a convertible, less draught, less noise, warmer, a much more relaxed and enjoyable drive, get one, you won't be dissapointed.
The frame of mine fits into two slots and the horizontal section tucks behind the seat, I don't know if it is oem or after market, information on these is very sketchy.
Richard Kabat
E type ( XK-E )
Sep 3, 2013 01:45 PM
Davidd 21
UK & Eire
Oct 20, 2012 01:20 PM
emgun
May 11, 2012 09:43 PM
jamjax
Oct 28, 2011 04:31 PM
jagpro69
Jul 18, 2011 11:10 AM
