Won't drop
Old Feb 28, 2015 | 10:21 AM
Ivor4ever's Avatar
Default Won't drop
Hi all
My drivers door window will not motor down when opening door motors up when closing bit of a pain because catches door surround
Please help
Old Feb 28, 2015 | 10:27 AM
cjd777's Avatar
Ivor, Have you set the top position with the switch. Hold the up button after the window reaches the top until you hear a ping (click), that sets the window. If that doesn't work and your battery is fine, a new micro switch may be in your future.
Wayne
Old Feb 28, 2015 | 11:30 AM
Ivor4ever's Avatar
Tried that seams to be trying just not dropping sticking somewhere will it need adjusting?
Old Feb 28, 2015 | 12:28 PM
larueb's Avatar
Is your battery strong. It will cause problems with the window movement on door opening
Old Feb 28, 2015 | 01:35 PM
Ivor4ever's Avatar
Battery ok passenger window fine just not pulling window down just needs push and it drops to right height
Old Feb 28, 2015 | 02:59 PM
Gus's Avatar
Gus
Attached you will find a oneline for your car showing the locations of all the switches and control module in your doors/car.
Link http://www.jagrepair.com/images/Auto.../jagxk1997.pdf
Each door has a latch mechanism and control module. The latch mechanism has 3 micro switches all working to control the function of the door, security and window systems. Before you begin to open the door panel to see what is going on I would recommend that you spray the door latch mechanismwith WD40 from the outside and exercise the door open and close with the window down. The window down to prevent damage to the window seals. Give that a try first! If it does not work you can swap out the control modules from one door to the other to see if it is the module but be informed you do not want to do a thing in the door with the battery connected.
Old Feb 28, 2015 | 03:04 PM
Gus's Avatar
Gus
Question did you try to reprogram the window with the door open? If that is what you did you need to do it with the door closed.
Old Mar 1, 2015 | 09:33 AM
Ivor4ever's Avatar
Thank to all re program oil all links adjust a few bits seams ok now
Dave1109971
Dec 15, 2015 06:16 PM
jagtoes
Oct 14, 2015 06:15 PM
3jagfamily
Oct 1, 2015 01:49 AM
CaptainHam
Oct 1, 2015 01:38 AM
HuncaMunca
Sep 27, 2015 02:47 PM
