won't start after battery disconnected
Old Jan 16, 2015 | 02:01 PM
jeremys's Avatar
Default won't start after battery disconnected
Hello
I disconnected the battery on my 01 xk8 to remove instrument cluster and replace blown bulbs, followed instructions found on U-tube video to the T
6 out off 8 bulbs were blown .Replaced and reassembled Car turned over but didn't start then battery went dead, I connected a spare battery car turns over fine but doesn't start, fuel cutoff not engaged, could this just be low battery or some other reset needed. I found it strange that radio did not need to be reset after a battery disconnect. I am currently charging battery,
Any advice would be most helpful. Oh and all bulbs in dash now light.
Thanks in advance for any help
Jeremys
Old Jan 16, 2015 | 03:01 PM
WhiteXKR's Avatar
When was the last time the car had run? If the battery went dead quickly it sounds as if it may have been parked for some time. The fuel pump has a habit of failing after sitting for a few weeks.
In any case disconnect the battery for a minute after recharging it to reset the systems again after being exposed to low voltage from the weak battery.
Old Jan 16, 2015 | 04:33 PM
jeremys's Avatar
Default no start after bat disconect
Thank you for the advice, the car was sitting for about 2 weeks since last run, after recharge should I reset system by grounding Positive to Neg terminal?
Thanks for the response
Jeremy
Old Jan 16, 2015 | 04:37 PM
brgjag's Avatar
A fuel pump will go bad if the car sits for a few weeks?
Old Jan 16, 2015 | 06:42 PM
WhiteXKR's Avatar
Jeremy
Yes you can do that (with a battery terminal disconnected of course), but waiting a minute or two on a simple disconnect is equivalent.
Old Jan 16, 2015 | 06:43 PM
WhiteXKR's Avatar
No, only if the pump is old and on its way out anyway, this often does them in on the 4.0 liter cars.
Old Jan 17, 2015 | 08:07 AM
Jon89's Avatar
And on the occasional 4.2-litre car as well....
Old Jan 17, 2015 | 10:41 AM
jeremys's Avatar
Default no start after batt disconect
Thank you to all those who offered advice ,I am happy to say the issue is resolved after a full recharge and removing ground cable and touching it to the pos cable the engine started, as per another post I read I ran the car at 45-50 mph for about 45min to reset Computers? anyway runs great.
Now I've got all my dash lights back onto my next project repairing seat controls.
Jeremy
dsnyder586
Dec 29, 2024 07:39 PM
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
