XJ8 to XK8 floor shifter
Old Sep 5, 2014 | 09:08 AM
metalmarty's Avatar
Default XJ8 to XK8 floor shifter
Can anyone confirm that the floor shifter assembly from a 99-03 XJ8 is interchangeable with a 98 XK8? They look the same, and both hook up to the same transmission, but you never know sometimes.
- Marty
Old Sep 6, 2014 | 09:12 AM
metalmarty's Avatar
Am I going to be a guinea pig for this? Someone has to have tried it.
Old Sep 6, 2014 | 11:15 AM
I read this last night and was sure someone would already have done it. It seems not!
The Gear Change Control isn't supplied as a single component but a check of the P/N's for the major parts of Gear selection Illumination Module (item 3) and the Housing and Sleeve (item 5) shows a close match between the XK8 and XJ8:
XK8
XJ8
I'd take the risk and go for it.
Old Sep 6, 2014 | 03:23 PM
kg7657's Avatar
Hi,
I have actually done this 'conversion'. Although the XJ8 and XK8 gear selectors are similar I found that the slightly narrower transmission tunnel of the XK8 made fitting the XJ8 selector mechanism tricky. I had to cut the metal side plate of the XJ8 down by removing a redundant bracket and cutting a 'triangle' of metal away to make the selector fit. Also a base plate hole needs enlarging as the mounting studs are slightly different.
cheers
Old Sep 6, 2014 | 06:02 PM
Welcome to the forum kg7657,
Old Sep 6, 2014 | 08:08 PM
metalmarty's Avatar
XK8
Attachment 95057
XJ8
Attachment 95058
This confirms it, thanks!
Old Sep 6, 2014 | 08:09 PM
metalmarty's Avatar
Originally Posted by kg7657
Hi,
cheers
This is precisely what I was looking for, thanks very much! If cutting some metal is all it takes, I'm in.
Old Sep 7, 2014 | 02:55 AM
Please take/post pics if you get the chance. It would be a very useful addition to the thread.
Old Sep 11, 2014 | 10:04 AM
metalmarty's Avatar
Will do, when I get around to it.
neruda
Oct 18, 2015 01:19 PM
Road Racer
Sep 19, 2015 04:08 AM
Road Racer
Sep 17, 2015 06:53 AM
Phil G.
Sep 12, 2015 07:42 AM
