xk8 2001 alternator issue -- need clarification
Old Nov 19, 2023 | 12:53 PM
tortugatoo's Avatar
Default xk8 2001 alternator issue -- need clarification
hi everyone -- hope someone can answer this. i replaced my xk8 (2001) alternator with a new Bosch unit. works fine...BUT, the dash message says its not charging. battery voltage is fine, charging voltage is fine. can't shut off the dash message using any know or regular method. mechanic says it will not shut off until you replace with original jaguar part. there must be a way to resolve this and eliminate that clearly incorrect message. help please. thanks.
Old Nov 19, 2023 | 02:19 PM
RichardS's Avatar
What if you do a full ECU reset?
Richard
Old Nov 19, 2023 | 02:37 PM
Jon89's Avatar
This is a common problem with aftermarket alternators on these cars. Always best to have your factory alternator refurbished with the correct genuine Denso kit. That is what I did back in the summer of 2018 for my wife's 2006 XK8.. No issues since....
Old Nov 20, 2023 | 01:01 AM
Y2KJag's Avatar
How do these cars know there is a different brand of alternator installed?
Old Nov 20, 2023 | 02:07 AM
Pistnbroke's Avatar
Did it say not charging before you changed it ? Is that why you changed it ? Re set and clear all codes .
What is the charging voltage ? Is the red ignition warning light out ?
Old Nov 20, 2023 | 02:20 AM
dibbit's Avatar
There is a single wire that goes from the regulator to the dashboard (major instrument pack) called "charge warning". I'm guessing that either isn't connected or whatever signal the instrument pack expects to get over that wire, isn't being sent by the non OEM regulator.
Old Nov 20, 2023 | 02:26 AM
Pistnbroke's Avatar
If that wire is connected the ignition warning light will behave correctly ..on with ignition off with engine running.
Old Nov 20, 2023 | 02:42 AM
dibbit's Avatar
If that wire is connected to a genuine OEM alternator - people seem to be saying that aftermarket alternators aren't compatible.
Old Nov 20, 2023 | 03:01 AM
Pistnbroke's Avatar
Its only a wire to the top of the field diodes nothing fancy. Did he put the 3 pin plug in the right way around ?
CHoseph38
Oct 21, 2023 10:00 AM
noterman
Aug 27, 2015 10:01 AM
looops
Aug 14, 2015 09:41 AM
vettegood
Aug 13, 2014 08:59 PM
Magnetvision
Nov 22, 2011 09:44 PM
