XK8 2002 Airbag Code 44
Old Nov 2, 2021 | 08:19 AM
Ken Rose's Avatar
Default XK8 2002 Airbag Code 44
Hello all! I was wondering if any of you have had experience with airbag code 44 - Impact sensor circuit fault – pass side. My car has been displaying this code for a while now and I'd like to get it cleared. I have tried to find pictures of where the front passenger impact sensor is located but haven't had any luck. If you've had experience with this problem I'd love to hear how you resolved it. Thank you!
Old Nov 2, 2021 | 09:57 AM
motorcarman's Avatar
I am guessing Pass Side means RH Side Impact Sensor?
The Electrical Guide is pretty clear where the the sensor is located.
(from the guide - figure 18.1)
CRASH SENSOR – SIDE, RH RH16 / 2-WAY CONNECTOR / BLACK BEHIND SAFETY BELT RETRACTOR / REAR QUARTER TRIM PANEL
Old Nov 2, 2021 | 10:04 AM
Ken Rose's Avatar
RH side that is correct. That's great info thank you very much! I was thinking it was at the front of the vehicle towards the headlight. This definitely helps me, thank you agian!
Old Nov 2, 2021 | 01:20 PM
As per the XK8 electrical Guide (figure 18.1) there are THREE impact sensors for your car.
Front
LH side
RH side
Old Nov 2, 2021 | 01:51 PM
Ken Rose's Avatar
If I'm not mistaken, in the 40's series of airbag codes for this XK8 (SAJDA42C52NA23202) there is 42 for the front sensor, 43 for the LH sensor and 44 for the RH sensor. I can't open that PDF with the illustration you are referring to but knowing that it is near the seatbelt retractor definitely helps a lot.
Old Nov 2, 2021 | 02:37 PM
B2296 Crash sensors status Ignition ON
NOTE: Sensors must be powered up to monitor electrical characteristics
Front sensor fault: Flash code 42
Driver side sensor fault: Flash code 43
Pass. side sensor fault: Flash code 44
DTC guide for you.
File Type: pdf
Smonop
Aug 19, 2024 10:46 AM
fishman
Nov 21, 2017 01:34 PM
Jon89
Dec 22, 2016 09:12 AM
cyberice
Oct 21, 2014 11:19 PM
cmccutcheon
May 18, 2013 02:46 AM
