XK8 4.2 starting difficulty when cold
Old Nov 14, 2016 | 02:14 AM
ajagger's Avatar
Default XK8 4.2 starting difficulty when cold
Hi. my 2002 XK8, first of the 4.2 model, has difficulty in starting when its cold. It turns over fine, but fire up until the second or third attempt. It wasn,t used for a most of this year. Once its warm, their is no problem at all. just when it cools down again. Any ideas would be greatly appreciated.
Old Nov 14, 2016 | 03:37 AM
Alan,
You've already posted a separate Intro so I've moved this post from New Member Area - Intro a MUST to XK8/XKR forum.
Old Nov 14, 2016 | 12:56 PM
ajagger's Avatar
Thanks Graham, much appreciated
Old Nov 14, 2016 | 01:22 PM
fmertz's Avatar
Originally Posted by ajagger
It wasn't used for a most of this year.
The standard answer is to check the battery. Here in the US, stores that sell batteries typically offer to load-test an old battery for free, in the off chance you need a replacement. The problem with an old battery is that under the load of a starter, the voltage may drop below what is acceptable to run the electronics (maybe 10V). Once past a certain point, no amount of recharging does the trick, and the battery needs to be replaced. The confusing part is that the old battery at that point seems to still be plenty capable of cranking, but in reality drops the voltage too much to be effective.
I am sure there are plenty of other reasons to have difficulties cranking, but this is a start.
Best of luck, keep us posted.
Old Nov 14, 2016 | 02:24 PM
ajagger's Avatar
Many thanks for that. The battery seems fine but from what you say there still may not be enough power to do the job properly
Old Nov 14, 2016 | 04:07 PM
frankc's Avatar
Once it does start does it idle ok?
Old Nov 14, 2016 | 04:45 PM
Johnken's Avatar
A jagger, no offense but what do you base seems fine on ? You really need to get it checked to be able to affirm status.
Don't feel like it ? Hook up battery charger, how many amps is it feeding ? When shows full, try a start with charger hooked up, did it make a difference like fmertz suspectso?
John
Old Nov 14, 2016 | 05:58 PM
Gus's Avatar
Gus
Try this! When the car is cold turn the key on count to 10 then start the car and see if that makes a difference.
Old Nov 15, 2016 | 02:57 AM
ajagger's Avatar
For a few seconds it's really rough then goes to idle absolutely fine and drives perfectly after that
Old Nov 15, 2016 | 02:58 AM
ajagger's Avatar
Thanks I'll try that. I think sediment might have settled between the tank and fuel lines because I didn't use it for months
Old Nov 15, 2016 | 03:00 AM
ajagger's Avatar
Thanks I understand what you mean. I'm just waiting to see if it settles down because if not using the car all this year
Old Nov 15, 2016 | 09:52 AM
fmertz's Avatar
If you suspect a fuel delivery problem, the fuel pressure value is available over standard OBD. A cheap ELM327-based diagnostic tool would show you the value "real time". Mine shows a pretty constant 55 psi, as I believe the sensor takes its value with a reference to the intake manifold already.
Old Nov 15, 2016 | 02:58 PM
ajagger's Avatar
Thanks very much for that info
Angrycanuck
Jan 3, 2017 10:22 AM
Dutch-R
Nov 19, 2016 11:51 PM
johncalvinyoung
Nov 15, 2016 11:25 AM
tech.advice
Nov 14, 2016 09:40 PM
hriant88
Nov 9, 2016 04:22 AM
