XK8 Coolant Loss
Old Jun 26, 2012 | 07:05 AM
diggypiff's Avatar
Default XK8 Coolant Loss
Hello everyone. I am relatively new to the forum, but have learned a lot from all of you already. I have a 2000 XK8 roadster with 102k on it. I thought I had it pretty much all in great shape now, having been through a broken tensioner, chain, bent valves, etc., the blown out hydraulic line in the windshield header, and some less drastic problems. But lately it has been consuming coolant at a rate of maybe half a cup per hour. I can't find any evidence of coolant outside the engine or under the car at all. I don't smell it anywhere, either in the engine bay, inside the car, or the exhaust. But the cooling system doesn't seem to pressurize, either. I just put a new coolant reservoir cap on it, and still no pressure. I have my own fears about this one, but do any of you have any suggestions, or experience with similar situations? Thanks for the help.
Doug
Old Jun 26, 2012 | 07:24 AM
steveinfrance's Avatar
The coolant tank is a known culprit
Here's a thread
https://www.jaguarforums.com/forum/x...or-leak-57962/
Old Jun 26, 2012 | 07:36 AM
WhiteXKR's Avatar
Welcome! Buy or rent a cooling system pressure tester kit. Pressurize the system without the engine running and you should see/hear the source of the leak.
mrplow58
Jan 21, 2024 05:53 AM
duecedriver
Dec 25, 2015 11:47 AM
willtoliv
Oct 2, 2015 12:18 PM
Johnken
Sep 15, 2015 05:46 PM
jimmiejag
Sep 9, 2015 02:56 PM
