An XK8 Project (1999MY)
Old Apr 29, 2014 | 09:23 AM
Rezzz's Avatar
Default An XK8 Project (1999MY)
I've decided to create a thread whereby I can update the progress on the restoration of my 1999 XK8. To date I have acquired;
1) All replacement suspension components including struts, mounts, rotors, calipers, all universals, stainless break lines, all bearings.
2) Water pump, aluminum thermostat housing, new thermostat, etc.
3) Tensioners', etc, etc. The motor was replaced under warranty with a second gen but I will change the tensioners out for third gen anyway.
4) Removing Transmission in the next week and then starting on a complete overhaul of the body.
I will continue to add pictures as the work progresses
Open to suggestions and comments and look forward to same. Have already picked up a ton of ideas including lamp upgrade that have led to the purchase of a number of goodies
Thanks in advance.
Attached Thumbnails An XK8 Project (1999MY)-front.png   An XK8 Project (1999MY)-1470854_10152083619430140_50271239_n.jpg   An XK8 Project (1999MY)-1483196_10152083636640140_2063553327_o.jpg   An XK8 Project (1999MY)-1479683_10152101437350140_1324071096_n.jpg   An XK8 Project (1999MY)-10300031_10152369458705140_1830839808062918557_n.jpg
An XK8 Project (1999MY)-10277755_10152369495450140_5421200515903737638_n.jpg   An XK8 Project (1999MY)-10151223_10152369495680140_5558337156082412048_n.jpg
Last edited by GGG; Apr 29, 2014 at 01:19 PM. Reason: add Model Year to thread title
Old Apr 29, 2014 | 10:01 AM
It would be useful to show the Model Year in your thread title. If you want it changed, I can edit it for you.
Old Apr 29, 2014 | 10:37 AM
Beep777's Avatar
Did you buy it in this condition or has it been sitting around in your garage awhile? If purchased, what did you pay?
B
Old Apr 29, 2014 | 10:59 AM
JSC's Avatar
JSC
I would like to make a suggestion or two.
Would it be possible to give estimates for price and time for the work done, or even complexity? I would be very interested the amount and time needed for suspension and brakes, since I willl probably have to do the same at some point.
This has the potential for a sticky or reference for anyone interested in getting or fixing a XK8.
Please keep us up to date on your progress!!
Old Apr 29, 2014 | 12:41 PM
Rezzz's Avatar
Please do Graham thanks!!!
Old Apr 29, 2014 | 12:44 PM
Rezzz's Avatar
My pleasure I am logging everything including parts cost and time and labour. My friend is a mechanic with over 25 years on foreign (meaning not from North America) cars and he will be doing the work with me. It is an after hours and weekend project. My other friend owns a body shop and that part of the work will be undertaken in a similar way.
Old May 2, 2014 | 12:50 PM
Rezzz's Avatar
Default Tell me this tensioner is new gen please?
Just took valve cover off. Is this a new metal tensioner? Fingers crossed please let me know your thought ?
Old May 2, 2014 | 03:00 PM
RJ237's Avatar
You win the prize, but what about the other side? There have been reports of only one being changed.
Old May 2, 2014 | 08:49 PM
Rezzz's Avatar
The other side as well. Great news now I can spend a little on some other things eh!
Old May 4, 2014 | 02:18 PM
steven300's Avatar
very nice,love the red.i repainted my 99 coupe four years ago and toyed with the idea of red since the inside was black.but then decided the original outside color of black was the way to go.i was suprised to find out that jag did not offer bright red with black interior...steve.
Old May 4, 2014 | 07:51 PM
Rezzz's Avatar
This is Phoenix Red with a black interior not sure what you mean did not offer?
Old May 4, 2014 | 09:27 PM
jimmiejag's Avatar
Default My Phoenix Red coupe
FWIW, my 1999 Phoenix red coupe has a Cashmere interior. Both the exterior and trim are the OEM colors, according to the door jamb sticker.
I've not seen many Phoenix red coupes and don't recall ever seeing one with black trim (interior). It's apparently even more rare.
Old May 5, 2014 | 07:58 AM
Rezzz's Avatar
Well then that makes me even more content, I guess I have something a little rare.
Old May 9, 2014 | 09:25 PM
Rezzz's Avatar
Parts List to Date
Brake pads front and rear
Parking brake pads and rebuild kit
New parking brake cables
Fuel pump
Fuel filter
New plugs
New slotted and drilled brake rotors
Brake caliper repair kit – two
Brake hardware kit – front two
Rear suspension stabilizer back end link kit
Rear shocks
Rear lowering springs Mina
Rear differential universal
Half shaft universals – full set
Half shaft spacers
Front shocks
Eccentric shank bolts
Rear wheel bearings and retaining rings
Tapper bearings rear
Front wheel bearings and retaining rings
Braided stainless brake lines
Entire radiator hose set
New thermostat
New thermostat housing aluminum
Coolant reservoir hose
New water pump
New octopus hose
Front hub spring clips
Shock mounts front and rear
Intake gasket set
Crank case hose
Breather intake hose
Old May 21, 2014 | 08:22 PM
Rezzz's Avatar
Making steady progress. Trany is out and on its way to the transmission shop
Attached Thumbnails An XK8 Project (1999MY)-photo2.jpg   An XK8 Project (1999MY)-photo.jpg   An XK8 Project (1999MY)-photo3.jpg   An XK8 Project (1999MY)-photo4.jpg   An XK8 Project (1999MY)-photo6.jpg
Old May 22, 2014 | 05:35 AM
ArtyH's Avatar
Your progress looks great as does the car. Its the same MY as mine so I am very interested in your posts. At this time I have just got over a problem with my car going into restricted performance mode and showing gearbox fault, it was the rotary switch. I still have it at the back of my mind I will have to switch out the autobox as occasionally the original one bumps a bit, of course it could be that it is still in learning mode, with new oil and filter I certainly hope so.
Your parts bill must be quite high now, hope you dont have to add much more to get the car back on the road. Good luck with the project.
Arty
Old May 22, 2014 | 08:28 AM
Rezzz's Avatar
Arty
Thanks Arty. To date my total cost in parts is $3918.78 US. The Transmission is going to be about $2200 US on its own. My budget for the project including new wheels tires, exhaust system, sound system, interior upgrade and refinish is $10,000.00 US
Old May 22, 2014 | 12:57 PM
Rezzz's Avatar
B
I inherited the car so essentially I received it at no cost. It had been sitting in storage for over 2 years
Old May 22, 2014 | 01:25 PM
Jon89's Avatar
Inherited an XK8, huh? I think we're distantly related. Can you check your inheritance documentation and see if there's anything for me, please?
Old May 27, 2014 | 07:56 PM
Rezzz's Avatar
Default Starting on the intake
Changing the intake gaskets, valley pipes, getting a little help from the Bud Man
Attached Thumbnails An XK8 Project (1999MY)-1622157_10152434495260140_8309666421436383879_n.jpg   An XK8 Project (1999MY)-10380906_10152434495345140_1196832196101247394_n.jpg   An XK8 Project (1999MY)-10294340_10152434495620140_4294389672429166622_n.jpg   An XK8 Project (1999MY)-10309210_10152434495130140_7758689500755093205_n.jpg   An XK8 Project (1999MY)-10425830_10152449026975140_548244933_n.jpg
