XK8 Radiator fans will not turn off-EVER - RESOLVED
Old Mar 12, 2016 | 08:25 PM
BillC's Avatar
Default XK8 Radiator fans will not turn off-EVER - RESOLVED
I have a 2000 XK8. The radiator cooling fans will NOT turn off...EVER. I have to disconnect the battery. When the car is cold in the morning and I attach the battery cable the fans kick on to high speed. The fans were acting a little odd by turning on to high speed after first start without the AC on but now they won't stop. I did detach the sender at the thermostat tower but the fans kept running. I don't have my repair CD with me. Could someone please tell me what the problem is and how I can fix it? I've read on this forum that it might be the FAN MOTOR RELAY for other fan related problems, could this be another sympton? If you think it is, can you please tell me where exactly it is located and where I could get one?
Thanks in advance,
BillC
P.S. This is a new problem that just started a few days ago.
Last edited by GGG; Mar 16, 2016 at 01:56 PM. Reason: Add 'RESOLVED' to thread title
Old Mar 12, 2016 | 09:57 PM
motorcarman's Avatar
The fan control relay module (a fancy set of relays in a plastic housing) is under the left headlamp assy accessed from under the car.
Sounds like the relay module is getting bad info or it has failed.
bob
File Type: pdf
Old Mar 13, 2016 | 03:49 AM
Originally Posted by BillC
I have a 2000 XK8. The radiator cooling fans will NOT turn off...EVER......
Welcome to the forum Bill,
You should add whether this has been the same since you got the vehicle or has recently happened to distinguish between a fault and a possible PO 'modification'.
Old Mar 13, 2016 | 09:05 AM
BillC's Avatar
Motorcarman, Thank you for the response. I will locate and unplug the relay to see if the fans stop. Otherwise I'm looking at a ECM?
GGG, Thanks for the welcome. I filled out the intro. Thanks for the reminder. Also, Ive edited my post to include that this is a new problem that just developed.
Old Mar 13, 2016 | 10:39 AM
DaveInVA's Avatar
Could also be one of the relays is welded up.
Dave
Old Mar 13, 2016 | 01:40 PM
BillC's Avatar
Dave,
Would you know what other relays I should check?
Thanks,
BillC
Old Mar 13, 2016 | 04:01 PM
Jandreu's Avatar
It's all in the file Motorcarman attached. Look at fig 4.2 and you will see the fans and how they are wired, follow the diagram to trace all circuits.
Old Mar 13, 2016 | 04:03 PM
test point's Avatar
If the ECM is seeing an 'open' from the temperature sensor rather than a few hundred ohms as indicated by your comment that you had disconnected the sensor connector and the fans are still running then pull the fan relays. On relay provides 12v to both fans (high) the other runs the fans in series dropping 6v on each (low).
If the relay(s) are operated under control of the ECM only then would I chase a computer issue.
Old Mar 13, 2016 | 06:04 PM
BillC's Avatar
Thanks guys. I see the electrical schematic shows two relays after the FAN CONTROL MODULE. (thanks motorcarman)
Can anyone tell me where the relays are located on my 2000 XK8?
Thanks again,
BillC
Old Mar 13, 2016 | 07:11 PM
Paul Pavlik's Avatar
Can anyone tell me where the relays are located on my 2000 XK8. Thanks again, BillC
See Post #2 Above
Old Mar 13, 2016 | 07:32 PM
BillC's Avatar
Originally Posted by Paul Pavlik
See Post #2 Above
I thought the fan control module and the two relays are three separate things. I understand the fan control module is located behind the left headlamp accessed from under the car. I was asking for the physical location of the two relays. Or am I misunderstanding.
Thanks,
BillC
Old Mar 13, 2016 | 07:47 PM
I thought the fan control module and the two relays are three separate things. I understand the fan control module is located behind the left headlamp accessed from under the car. I was asking for the physical location of the two relays. Or am I misunderstanding. Thanks, BillC
The Relays are mounted on the Fan Control Module. Mounted "Adjacent to the Left Hand Horn".
Old Mar 13, 2016 | 08:15 PM
BillC's Avatar
Thanks Paul.
Old Mar 16, 2016 | 09:01 AM
BillC's Avatar
UPDATE: Problem fixed! Found a welded shut 12v relay. Tapped it on the bench and plugged it back in. Fans worked fine. Ordered a new relay and replaced it. Fans now come on at the proper time. No more embarrassing battery unplugs.
Thanks so much for steering me to the right place. I love Jagforums.
BillC
Old Mar 16, 2016 | 09:37 AM
DaveInVA's Avatar
Glad it turned out to be something simple!
Dave
giandanielxk8
May 20, 2019 10:23 AM
Rick L
Feb 28, 2016 12:41 PM
Madbrad
Feb 27, 2016 07:17 AM
XxSlowpokexX
Feb 25, 2016 04:06 PM
Desiderata
Feb 23, 2016 08:56 PM
