XK8 Transmission noise
Old Sep 11, 2016 | 08:30 AM
geraldhull's Avatar
Default XK8 Transmission noise
1997 Jaguar XK8 with 28,000 miles
A week ago I noticed a very light hesitation when accelerating from a stop. A few minutes later a whining noise started coming from the transmission and, about a mile later, when I reached my destination and put the car in park I noticed a ticking noise from the transmission. About an hour later I drove the car around the block and the noises were still there.
There are no error codes coming up and the car did not go into 'limp home' mode.
I had the car towed home.
Any thoughts on what might be causing this?
Gerry
Old Sep 11, 2016 | 08:54 AM
I've moved your post to the XK8/XKR section where you will get better response to your question.
Old Sep 11, 2016 | 09:50 AM
Beav's Avatar
A ticking noise could be as simple as loose converter to flexplate fasteners. A hesitation could indicate low fluid level (and also account for a light whining.)
Old Sep 11, 2016 | 10:03 AM
RJ237's Avatar
The low mileage of your car is a negative in some respects, particularly as regards fluids. If you haven't done so flush the cooling and brakes, change the water pump and thermostat, maybe install aluminum tower. Replace the secondary tensioners.
As to the transmission, change the filter and fluid. Remove the forward valve body and install the upgraded main pressure valve. Explanation below:
http://jagrepair.com/images/AutoRepa...%20ZF5HP24.pdf
Shoreguy
Oct 1, 2016 01:21 PM
150FHC
Sep 18, 2016 07:03 PM
NIgor
Sep 6, 2016 02:45 AM
mel.lugo
Sep 4, 2016 10:55 PM
reedjs
Sep 4, 2016 10:13 AM
