XK8 valve cover upgrade
Old Nov 25, 2013 | 05:01 AM
g.dover's Avatar
Default XK8 valve cover upgrade
Hi everyone,
I am building a Ronart 152 incorporating a 4.0L V8 Jaguar engine which has the standard plastic rocker covers and plug covers. For aesthetic reasons I would like o fit aluminium ones if available. Does anyone out there know where I can get them or any alternative solution. Many thanks
Old Nov 25, 2013 | 05:32 AM
Welcome to the forum g.dover,
You have correctly chosen to post this question in Jaguar Engines forum but I think in this case it will get a better response in XK8/XKR forum.
I've therefore moved it to XK8/XKR forum but left a redirect in Jaguar Engines so you get double the chances of an answer!
I'm not aware of aluminium camshaft covers for the 4.0 Litre being manufactured in the UK and, if they are available from anywhere, this is likely to be in the US. Members here will be able to advise.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Nov 25, 2013 | 05:44 AM
Cambo's Avatar
I would look at chrome-plating the plastic ones.
Or maybe it would be possible to wrap them Alsa Corp | Strech Chrome Film
But with the heat in the engine bay the finish might not look great for long.
I seem to recall someone here on the forum wrapped their valve covers in carbon fibre look vinyl...
Old Nov 25, 2013 | 07:29 AM
The Coupe's Avatar
Go here: Paragon Design UK
Old Nov 26, 2013 | 04:50 AM
g.dover's Avatar
Default V8 Rocker covers
Thanks for the feed back, however I have looked at chrome plating and everyone tells me that unless the rocker covers are made from ABS plastic, chroming is not an option, unless you know otherwise? I am looking to have them machined from a block of aluminium, but suspect the costs maybe prohibitive.
Old Nov 26, 2013 | 05:51 PM
enderle's Avatar
Default Paragon Covers
This are coil pack covers the valve covers remain plastic. I have a set and had them custom painted for my car. He does good work. I'm pretty sure they were polished aluminum.
Attached Thumbnails XK8 valve cover upgrade-wp_20130928_10_24_23_pro.jpg   XK8 valve cover upgrade-wp_20130703_002.jpg
Old Nov 26, 2013 | 10:21 PM
g.dover's Avatar
This might be an alternative, but I share your concerns re. effect of heat in engine bay. Many thanks for you help.
Old Nov 29, 2013 | 11:15 PM
Beav's Avatar
Old Nov 30, 2013 | 04:12 AM
g.dover's Avatar
Default Chrome painting
Beav, Many thanks for the info, the video was really interesting and I guess the next challenge is to find someone in the UK who can do it for me. As they chrome plated a plastic valve cover, I assume the finish is resistent to the associated operating temperatures?
Old Dec 3, 2013 | 07:37 AM
Beav's Avatar
No idea, you now know as much about it as I do. Just tripped over it the other day while binge watching Jay's garage on YouTube and recalled your post.
I particularly like being able to tint the clearcoat. It would make for an interesting repaint, spraying an anodized look to an entire car.
Old May 17, 2014 | 07:53 AM
Beav's Avatar
http://tinyurl.com/l3s932w
Old May 17, 2014 | 01:20 PM
jonscot's Avatar
I just started palladium plating-leafing ( almost as shiny as chrome ) my intake runners as a dress up - let me see if the "glue" survives the heat load before I call it a success ...
Old May 18, 2014 | 04:19 AM
g.dover's Avatar
Default Jag Aluminium coil covers
I looked into the possibility of having a pair of rocker covers machine from aluminium billets, however the cost was prohibitive ( in excess of £3K). This being the case, I opted to have the coil covers machined from billets, which were also expensive mainly due to the CNC programming time, however now that it's been done any others required would be substantially cheaper, so if any one is interested in a pair, let me know and I can arrange it. They look really great and will no doubt outlast the engine. I have photos if anyone is interested!!!
Old May 18, 2014 | 05:02 AM
g.dover's Avatar
Default Aluminium rocker and coil covers for Jag V8 engines
Photo below.
Old May 18, 2014 | 12:04 PM
mike6348's Avatar
Hydrographic coating? They may not have chrome but the carbon fiber looks good.
https://www.jaguarforums.com/forum/x...2l-xkr-112687/
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
02jagstype
23
Oct 23, 2022 07:03 PM
jaggermang
Sep 8, 2015 07:07 PM
