XK8 wheel/tire fitment question
Old Mar 6, 2009 | 06:39 PM
vagearhead's Avatar
Default XK8 wheel/tire fitment question
I've got a chance to get a set of BBS Detroit wheels with 285/30 ZR 20 99Y Pirelli P Zero Asimmetricos for a really good price. I'm going to see them tomorrow but the seller says all four tires are the same size not staggared like on a stock XKR. I'd like to know if a 285 tire will really fit the front of an otherwise stock XK without any rubbing or interference issues and if the stock steering box is strong enough to handle such a wide front tire?
I'd also like to know if there is a different backspacing between the front and rears on these wheels or any other way that I can tell if I'm really getting a two fronts and two rears, not just a set of 4 rear wheels.
Old Mar 8, 2009 | 11:27 PM
H20boy's Avatar
you should be able to check the inside wheel well and look for a raised stamp - "bolt pattern x 8.0" and rear should be "bolt pattern x 9.0". <- these are on my 19" wheels IIRC, hopefully your Detroits will have the same data.
Old Mar 9, 2009 | 10:08 PM
vagearhead's Avatar
Thanks H2O boy,
It turned out the seller didn't really know what he had. The wheels and tires were the correct stock sizes, in great shape and legit so now the XK has a new look!
Old Mar 10, 2009 | 10:13 AM
H20boy's Avatar
Excellent, I bet they look fantastic. Pic when you get them installed!
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
mrplow58
Jan 21, 2024 05:53 AM
roby
Sep 20, 2015 01:54 PM
Wolfy
Sep 10, 2015 09:50 AM
