XKR 02 driver door problem.
Old Apr 14, 2020 | 11:24 AM
mark english's Avatar
Default XKR 02 driver door problem.
Having a problem with driver door ,no puddle light and no interior lights when door is opened and will not lock ,passenger side works just fine it terms of puddle lights and interior lights when door is opened.,but will not lock.
any help to point me in the right direction would be appreciated.
Old Apr 20, 2020 | 09:51 AM
Welcome to the forums Mark,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Apr 20, 2020 | 11:48 AM
avern1's Avatar
It sounds like the micro-switches in the lock mechanism are stuck and the door module can't tell if door is open or closed. Before tearing it apart I would recommend opening the door and spraying it down heavily thru the lock are with wd-40. I would also spray thru the key latch. Spray it down and cycle the door a few times to see if they will free up.
Old Apr 20, 2020 | 03:08 PM
Johnken's Avatar
Mark what year is the car?
Does the dash display say drivers door open?
Assume that you have a convertible. Does the drivers window drop properly when handle opens door?
Does anything electric work on the drivers door - ever? ( mirrors, window up down does it control passengerwindow properly)
What happens when: door shut, car running? did she used to auto lock in drive? does either door auto lock?
You outside, press lock on key fob. What do locks do?
Car off, press driver door lock handle = what happens. Press pass door handle =?
car running press lock =? Pull lock =?
If it's an earlier car a bad micro switch will: force door open message on dash. Windows will drop everytime you touch a door handle (car thinks door is shut and latched). Puddle lights wi not be lit.
We look forward to more information mark
Old Apr 21, 2020 | 12:43 AM
Johnken's Avatar
Mark just noticed the 02 in your messages title. The reason I asked about the year is because earlier cars like mine had a lot more items tied to the micro switch in the door latch. If the switch failed = door closed, the puddle lights won't turn on . From trouble shooting this with others over the years I found that at some point,not sure about 2002, the puddle lights are triggered by something else. I expect the Drivers Door open message and the window drop are switched through the door latch for all years, but m.j maybe someone remembers better than I do.
John
Old Apr 21, 2020 | 07:43 AM
Ok thanks for the help guys .
car used to auto lock when put in gear.
Single beep when trying to lock with fob.
Window doesn't reset driver side.
seeing as the passenger door is ok ,i was thinking I would swap out the control module to see if that's it ,if not I'm guessing micro switch.is this a good plan ?
mark
Old Apr 21, 2020 | 10:15 PM
DavidYau's Avatar
Default Maybe different problems caused by door latch microswitches
Mark
I would dive into the door latch first to check out its 3 microswitches. Straight forward job if you have small hands to work in the door cavity. Our Rev Sam has a Youtube How To video.
I would caution to disconnect battery and/or window fuse for the sake of safety.
Plus Rev Sam made one error in disconnecting the vertical link. Just unsheathe the plastic collar by pushing down the plastic to reveal the metal male/female link that then slides out.
Good luck and let us know what you find. I have spares of these microswitches in a box as they seem common throughout the car.
Lots of other threads on this replacement in this door latch location, so is a common problem due to age.
Old Apr 22, 2020 | 05:45 AM
Originally Posted by DavidYau
Mark
https://m.youtube.com/watch?v=DV1hy3AYni0
ok thanks I'll do that first david.thanks
Old Apr 22, 2020 | 12:05 PM
Ok great,it was the latch micro switch ,I replaced it with the d2sw- 3l3ms from mouser electronics. $6.00 .
thanks for all the help ,
Mark.
maniqz
Mar 29, 2017 01:47 PM
Salu498
Jul 18, 2016 10:20 PM
Malihide
May 25, 2015 07:11 PM
Cadillac
XJ40 ( XJ81 )
Aug 7, 2009 12:53 PM
