XKR 100 Glasgow - Engine Failsafe
Old May 11, 2013 | 07:49 AM
ally1873's Avatar
Default XKR 100 Glasgow - Engine Failsafe
Hi,
Can anyone help with my xkr 100 warning messages. It has Engine failsafe mode--cruise control not available--Incortrect part fitted, Took it to Jag garage in Paisley, He connected it to his computer and was told i needed a new brake switch and that would take it out of failsafe mode, No it didn't. Now been told all faults "COULD" stem from a faulty adaptive cruise control module. Any suggestions ?. Where could i get a Adaptive cruise module ? Are they expensive ?.
Any help would be very much appreciated.
Thanks Alex.
Old May 11, 2013 | 06:32 PM
Alex,
I've moved your question from UK Region section to XK8/XKR section. You'll get more views from members with the same model in this section.
If the garage gave you the actual codes and not just an explanation, then post the codes here.
Old May 12, 2013 | 12:37 AM
flay's Avatar
Have you done anything to the J gate area recently?
Old May 12, 2013 | 02:47 AM
steveinfrance's Avatar
If changing the brake switch didn't fix it it is probably the control module
https://www.jaguarforums.com/forum/x...failure-90835/
Old May 12, 2013 | 09:51 AM
ally1873's Avatar
Hi,
No i havn't done anything to the J gate.
Old May 12, 2013 | 09:58 AM
ally1873's Avatar
Hello Again,
Sorry i did remove a few bits around the J gate to reach the hazard warning switch module that i needed to replace.Thanks Alex.
Old May 12, 2013 | 10:23 AM
Dogbreath's Avatar
If you do need a module, try Trevor
Home Page
Trevor is a decent chap and will almost certainly be able to assist.
Old May 12, 2013 | 01:22 PM
ally1873's Avatar
Hi,
I think i tried his Ebay shop already, but i'll send a email again,
Cheers Alex
Old May 12, 2013 | 01:58 PM
RaceDiagnostics's Avatar
If you plan to be in Edinburgh sometime this week I can put my tester on it for you and give you the codes.
Old May 13, 2013 | 05:51 AM
ally1873's Avatar
Hi
Thanks for that, The car is going in to get a part respray this week, Could i bring it out when thats done ?.
Thanks Alex.
Old May 13, 2013 | 03:30 PM
Np problem.
Jim
Old May 16, 2013 | 12:37 PM
flay's Avatar
Originally Posted by ally1873
Hello Again,
There are some micro-switches along the J gate path, they are reading where the shifter is. Any damage there can cause a lot of trouble codes. Check also the connectors. It was a recent post in Xj8 sub-forum about some similar messages.
Old May 17, 2013 | 11:05 AM
xjrguy's Avatar
Hi,
Thanks Alex.
Have you by chance also seen the message "Low Brake Fluid" during any of this??
Is this business intermittent or there at every start??
Seen any peculiar action at the Climate Control Panel??
Cheers,
Old May 18, 2013 | 07:47 AM
ally1873's Avatar
Hi
The dash warnings are there all the time, The only other one i noticed was, low coolant level, But thats seems ok now. Not noticed anything in climate control.
Thanks Alex...
toronadomike
Jan 22, 2026 10:13 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Beardy
Sep 18, 2015 10:00 AM
obwoodie
Sep 3, 2015 07:45 PM
TC Johnson
Sep 2, 2015 09:30 AM
