XKR 2003 Engine Check Light on. Can I check solution please?
Old Jul 28, 2013 | 11:50 AM
kmmoore1013's Avatar
Default XKR 2003 Engine Check Light on. Can I check solution please?
Hello guys (and girls),
I just wondered if someone could offer me some advice please, regarding my 2003 XKR and a couple of faults that have appeared recently...
I have had this car for about 15 months, and just recently, the Engine Check light came on.
This seemed like a good excuse for me to buy one of these OBDII diagnostic kits that I have been meaning to treat myself to, so I bought the Auto Enginuity along with the Jaguar add-on, and gave it a whirl
Anyway, it came back with a couple of DTC codes, and I just wanted to see if you could offer any advice please, and see if my plan of action should be roughly what is needed?
Here is a picture (sorry for the poor quality) of the screen report:
http://i1055.photobucket.com/albums/...ps214cdd9d.jpg
So, it looks like P1646 seems to be the Engine Check Light culprit (would I be right in saying that?) Would it be OK to drive the car (with care) with this error? (basically to take it to a garage, which could be upto 30 miles away)?
I am assuming that this is a simple enough fix, to replace the faulty o2 sensor?
Secondly, the C1446 error code appears to be a faulty Brake Light Switch (which would make sense, as I have been having intermittent "Check rear lights/Cruise not available" warnings for a few weeks now, but never had time to get it looked at.
Again, this seems to be a fairly straightforward fix, in replacing the Brake Light Switch (though appears to be quite tricky for a novice to do, so I will ask my garage to do both fixes).
I am assuming that the P1000 is because the Auto Enginuity was not able to do a complete scan (something to do with having to short pins 7 & 15 to complete the scan)...but I think that is more an interface (AE) problem, and not my car, so I am not too concerned about that, for now...
So, any advice would be gratefully appreciated, but would what I think be the likely culprit for both of my faults?
Many thanks for the help. Very much appreciated.
Cheers,
Kevin
Old Jul 28, 2013 | 12:44 PM
Paul Pavlik's Avatar
P1000 is not a Trouble Code. It means "Emission Monitors Not Complete".
P1111 is Emission Monitors Complete".
After Clearing Trouble Codes, P1000 will be set until a specific Driving Cycle has been completed.
After the Driving Cycle is completed, P1111 will be set.
Old Jul 28, 2013 | 12:52 PM
Thanks,
I am not overly concerned about the P1000 code. I am sure that will get sorted once everything else is fixed.
Cheers,
Kevin
Old Jul 28, 2013 | 12:58 PM
OldMike's Avatar
This is a pretty good thread on this issue -- P1646 Error Code: Which Oxygen Sensor Do I Replace? 2002 X-Type 2.5L - Jaguar Forums - Jaguar Enthusiasts Forum
You can drive it with a bad o2 sensor, as far as I know.
BTW you should be able to post the actual photo in your post by using the photobucket direct link and pasting it in to the window that pops up when you click on the photo icon (looks kind of like a yellow postage stamp!) at the top of the post input box.
Attached Thumbnails XKR 2003 Engine Check Light on. Can I check solution please?-dtc_zps214cdd9d.jpg
Old Jul 28, 2013 | 01:08 PM
Yeah, sorry 'bout the photo link...I pasted the wrong link initially, but as I'm new, I'm not allowed to edit my posts yet. But thanks for posting the pic...properly!!
Cheers,
Kevin
Old Jul 28, 2013 | 02:40 PM
Originally Posted by kmmoore1013
............. but as I'm new, I'm not allowed to edit my posts yet..........
Kevin,
There is no restriction on editing your own posts - use the black Edit button at the bottom right of the post you want to edit.
The only amendment members cannot make is changes to a thread title.
Old Jul 28, 2013 | 02:54 PM
Originally Posted by GGG
Kevin,
I am pretty sure new members need to "acquire" a bit of status before they can edit their own posts...
There is no Edit button, only the Quote, Multi-Quote, and Quick Reply icons.
Old Jul 28, 2013 | 04:31 PM
Gus's Avatar
Gus
Use this link to translate your codes.
Link for “P” codes http://www.jagrepair.com/DTCforms/X1...C_OBDII_R1.pdf
Link for “C” codes http://www.jagrepair.com/DTCforms/X103_C_DTC.pdf
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
kesslari
Aug 31, 2015 10:20 PM
daro31
Aug 27, 2015 09:26 AM
