XKR calipers on an XK8
Old Dec 28, 2012 | 11:18 PM
anthonyisd3ad's Avatar
Default XKR calipers on an XK8
Is it possible to swap the XKR Brembo's onto an XK8? I plan on doing the ls swap sometime within the year and being that I feel braking is a weak point on the XK8 as it is I would like to upgrade them before the ls is in
Old Dec 28, 2012 | 11:26 PM
giandanielxk8's Avatar
I was always under the impression that the XK8 calipers were the same as those on the XKR minus the fancy racy paint job. If they are different, then I don't see why it can't be done. I'm no expert though, so take my opinion with a grain of salt.
Old Dec 28, 2012 | 11:49 PM
I was under the impression that the XKR calipers are 4 piston calipers. I would assume with the size the caliper has to be more powerful than the XK8 especially being that an XKR with a 4.0 has 80 more hp and the 4.2 has 100 more over my 4.0
Old Dec 29, 2012 | 12:28 AM
xenophobe's Avatar
The XKR comes with Brembos standard. The upgrade is if they were painted red or come with cross drilled discs.
Old Dec 29, 2012 | 03:00 AM
XKRacer's Avatar
That was only on later XKRs early cars had standards looking brakes but the XKRs had bigger discs which used bigger carriers.
Yes you can fit brembos but u will have to tap the upright holes out to 14mm x 1.5 pitch if you wanted to use the correct bolts
Old Dec 29, 2012 | 08:20 AM
user 2029223's Avatar
Banned
Has anyone mentioned that your wheels may no longer fit after you up grade the calipers? I'm just saying..........
Old Dec 29, 2012 | 09:05 AM
XKRacer's Avatar
Indeed that is correct but you can get away with 18s...... not all though..... some require a spacer
Old Dec 29, 2012 | 01:01 PM
RCSign's Avatar
The Brembos became options on XKR's in 2001. then in 2003, they became standard.
Old Dec 29, 2012 | 02:43 PM
pgguy's Avatar
Default XKR brakes on XK8
Looks like it's possible to put XKR brakes on XK8 with slight mod...found this video starts at 1:40
Old Dec 29, 2012 | 04:33 PM
cadmium's Avatar
the xkr comes with brembos standard. The upgrade is if they were painted red or come with cross drilled discs.
that was only on later xkrs early cars had standards looking brakes but the xkrs had bigger discs which used bigger carriers.
I am unsure about what brake system I have on my 05 XKR (originally from Japan). I do not have cross-drilled disks and the calipers are painted silver with "Jaguar R" on them. I'm perfectly happy with them but when it comes time to replace the pads I want to look at aftermarket replacement options.
Can anyone help me positively identify the calliper type so I know what to ask for when it comes time to replace the pads?
Here's a photo.
Old Dec 29, 2012 | 04:58 PM
XKRacer's Avatar
You have brembos.... You can get ferodo pads for them which are better
Old Dec 29, 2012 | 05:48 PM
cadmium's Avatar
Thanks! I appreciate your help!
Old Dec 29, 2012 | 05:49 PM
JgaXkr's Avatar
You can also install Alcon calipers from a later XKR.
Old Jan 1, 2013 | 03:12 PM
NikasilNik's Avatar
By shear coincidence , XKRacer fitted Brembo's to my 1998 XK8
A relatively straightforward job ................ Thanks Tony !!!!
Happy New Year to you ,
NikasilNik
Old Jan 2, 2013 | 04:54 AM
XKRacer's Avatar
Always a pleasure Nik
Old Jan 2, 2013 | 10:03 AM
This is awesome! I'm so glad it can be accomplished. With the lack of aftermarket on these cars it gets boring but with the ls swaps becoming more popular it put a new spark in this car for me. My b6 s4's timing guides and cam adjusters broke and parts alone for the timing components are 4k plus you need to rent 3 tools from Audi and pull the motor to do the job. Needless to say I'm not doing that work I'm selling the car at auction and decided to give my xk8 another shot.
Old Jan 2, 2013 | 03:39 PM
H20boy's Avatar
Welsh is still trying to unload a few of these old stock front brembo upgrade packages...if you want new. Welsh Enterprises, Inc - Jaguar XK8 / XKR (97-06) Brakes Front Brakes Parts - Brembo Performance Front Brake Kit - XJ8 XK8
Old Jan 2, 2013 | 04:01 PM
XKRacer's Avatar
I don't think that is a bad price considering it even gives you the back plates, shame they don't have the rears also
toronadomike
Jan 22, 2026 10:13 PM
mrplow58
Jan 21, 2024 05:53 AM
wvanepps
Oct 4, 2015 10:01 AM
jnyaap
Sep 13, 2015 07:04 PM
philwarner
Sep 5, 2015 10:05 AM
