XKR Engine Lump
Old Mar 28, 2014 | 09:29 AM
CharliePar's Avatar
Default XKR Engine Lump
Hi,
I have a 2001 XKR Convertible with a seized engine. Crankshaft will not budge at all.
As I search for a replacement engine and consider my options, a couple of questions arise:
1. Is it possible to replace the 2001 engine with a later model year unit?
I.e., a 2002 or 2003? What about a 2004 or later 4.2?Are there any electronics or space/fit problems with later MY engines?
2. Is it possible to remove the engine and leave the transmission in the car, bearing in mind that I cannot rotate the crank and access all of the torque converter bolts? Will the torque converter just come off the transmission input shaft? Is this just a fantasy?
Thank you for any advice and counsel!
Charlie
Old Mar 28, 2014 | 10:14 AM
dsnyder586's Avatar
1. Yes- has been done before and documented in a thread some tweaking is required to make it work.
2. Yes, TC will slide off- have you tried rotating both directions with force?
Old Mar 28, 2014 | 10:24 AM
CharliePar's Avatar
Thank you.
I have tried to rotate the crank in a clockwise direction with a breaker bar with a pipe extension with the most force. I pushed it counterclockwise but with less force. I'll try going counter clockwise with more behind it.
Old Mar 28, 2014 | 11:03 AM
dsnyder586's Avatar
I bought an XJR with a couple of thrown rods and it was locked up- I pushed the crank back and forth until things were a bit looser and was able to turn it enough to remove the TC bolts. I later found a piece of a connecting rod embedded in the side of the motor!
Seller- "My wife overheated it, but it was turning over fine when we got it home, just wouldn't start" Sure buddy. I fortunately bought it at a price that reflected a parts car.
Old Apr 7, 2014 | 04:14 PM
CharliePar's Avatar
Does anyone know the bolt size of the threaded holes on the firewall side of the cylinder heads. I.e., the ones for attaching the lifting eyes during engine removal?
Old May 28, 2014 | 10:02 AM
CharliePar's Avatar
Update:
I have removed the engine and stripped it down to the short block. I took it to a reputable machine shop where two spun rod bearings are being fixed/repaired and replaced. Engine block has very low mileage and is otherwise in excellent condition.
I'm doing lots of parts washing and parts gathering in preparation for the upcoming reconstruction.
Old May 28, 2014 | 11:13 AM
Jandreu's Avatar
Good for you...I was going to suggest an LS1 swap.
Old May 28, 2014 | 04:48 PM
dsnyder586's Avatar
I would be interested in the parts costs etc for this- please let us know.
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
TC Johnson
Sep 2, 2015 09:30 AM
