XKR passenger door central locking failure
Old Jul 21, 2013 | 08:39 AM
steely's Avatar
Default XKR passenger door central locking failure
Hi, my passenger door fails to lock from the key fob, resulting in the driver door locking/unlocking its self a few times before the alarm sounds, if I manually lock the passenger door the driver door locks ok with the fob, however when I unlock, the passenger door remains locked and the driver door mechanism activates a few times. I can hear a click from the passenger door, so suspect there is a relay in there that is working, I assume there is some kind of motor to operate the lck mechanism and that has failed.
Any experience with similar problem?
Thanks.
Old Jul 21, 2013 | 08:46 AM
jimbov8's Avatar
I would think it may be stuck however, check the fuse in the passenger side fuse box first.
If that is ok then you may have to take the door card off and get inside to look at the linkages and the mechanism.
Old Jul 21, 2013 | 08:56 AM
WhiteXKR's Avatar
The self cycling of the door latch is usually symptomatic of a microswitch failure in the latch mechanism.
Old Jul 21, 2013 | 09:09 AM
bsprowls's Avatar
I had these same symptoms a couple of months ago. Solved it with a complete cleaning of the door latch mechanism parts. See this thread:
https://www.jaguarforums.com/forum/x...oswitch-90184/
Old Jul 21, 2013 | 09:19 AM
Cleaning can often give an extra lease of life to a failing Door Latch Micro Switch but, given the low cost of a replacement against the time required to remove and refit the Door Latch again when it does fail, I'd go for a replacement Micro Switch.
Old Jul 21, 2013 | 12:51 PM
steely's Avatar
Thanks for the advise.
I will replace the switch mechanism.
Now, any advise for removing the door panel and switch ?
Old Jul 21, 2013 | 01:19 PM
Check Reverend Sam's video for the procedure:
Old Jul 24, 2013 | 02:26 PM
steely's Avatar
I now have no central locking on either door, checked fuses, is it likely to be a switch failure on both doors or anything else I should look for ?
Thanks.
Old Jul 24, 2013 | 02:35 PM
jimbov8's Avatar
Hi Steely,
What exactly have you done in trying to fix this. Have you replaced or tested any switches?.
Old Jul 24, 2013 | 03:03 PM
steely's Avatar
Nothing yet, I was going to remove the passenger door panel and lock mechanism at the weekend, today the drivers door stopped working too but since posting earlier, I disconnected the battery, with the idea to start looking at the door panel, but decided it is a weekend job after all, after reconnecting the battery the drivers central locking is working again!
Could a bad battery have stopped the central locking working? I have no issues starting the car, so I have no reason to suspect it.
Does the central locking cancel out after a certain time due to the passenger door failure ?
I will get workong on the passenger door on Saturday.
Originally Posted by jimbov8
Hi Steely,
Old Jul 24, 2013 | 03:08 PM
jimbov8's Avatar
Before you rip it all apart, it will not hurt to fully charge the battery and give it one more try.
You may well have to get into the door and remove the mechanism to test the switches.
These cars do act up in the strangest of ways with even the slightest drop in voltage from the battery.
You certainly won't lose anything by charging it anyway.
Old Jul 24, 2013 | 03:27 PM
steely's Avatar
I can't find any evidence of the battery being replaced in the last 5 years, so could well be a battery issue, will get on it. Thanks.
Old Jul 24, 2013 | 05:29 PM
If you have an OE Jaguar Varta battery fitted, the manufacturing date is stamped into the top of the negative post.
(click on the photo to enlarge it)
The code is WW-YY for Week number and Year. Mine is 23-12 for the first Week in May 2012.
On my last four Jaguars, the batteries have needed replacing at between five and six years old. With weird electrical faults on these vehicles, always eliminate battery charge and condition before assuming component failure.
Old Jul 24, 2013 | 07:16 PM
WhiteXKR's Avatar
Also a hard reset or two should always be tried with a known good, fully charged battery before trying any other repair for a problem like this.
Old Jul 25, 2013 | 05:34 AM
steely's Avatar
What do you mean by a hard reset ? Will removing the battery suffice ?
Old Jul 25, 2013 | 05:39 AM
jimbov8's Avatar
The hard reset is achieved by disconnecting the battery leads and holding them together for about 15 to 20 secs.
Effectively discharging the capacitors in the system and wiping the memory.
The same is achieved by disconnecting the battery and allowing the capacitors to discharge naturally.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
bdboyle
Sep 4, 2015 06:16 AM
