XKR Remote Battery Fob
Old Apr 8, 2009 | 01:15 PM
Karl's Avatar
Default XKR Remote Battery Fob
Hi
As you may have seen from a previous thread; I have just bought a 1999 XKR. The lock, unlock and boot release buttons on the remote key fob were working intermitently (but the lights button worked every time, wierdly...) so assuming the batteries were dying, I changed them.
Now the fob doesn't work at all and I know the batteries are good. Having read the hand book I can see the fob sometimes gets de-coded (although I am sure I did not press any buttons while changing the battery)
Is this the only explanation and is there a way of me fixing it without taking into Jag to be done?
Many thanks
Karl
Old Apr 8, 2009 | 05:33 PM
Brutal's Avatar
Trunk open, drivers door open, left foot on ground, pull back and hold the bright hi beam stalk and turn the key to the first position. Now flash the light stalk 4-5 times youll hear a chirp that the security module is in programming. Press the unlock on the remote, it should tone again then turn key on and off that should reprogram the remote unless theres a fualt
Old Apr 8, 2009 | 06:14 PM
Brian2000XKR's Avatar
Thanks! I have always wondered how that was done. I'll make a note of it for future reference.
Brian
Old Apr 8, 2009 | 06:18 PM
test point's Avatar
Brutal,
You didn't mention the tongue position.
. . . or that any other other fobs will no longer work. All fobs have to be programmed at the same time.
Old Apr 8, 2009 | 10:35 PM
Brutal's Avatar
no thats keys not remotes, except the new smart keys. You dont need all the remotes for back door programming. And only need them if using the IDS and then selecting yes when it ask if you want to delete..The tongue position only matters if your wife/GF is doing the programming in a dress, then the left leg out REALLY matters...
Old Apr 9, 2009 | 06:16 AM
test point's Avatar
Brutal,
I assumed you were joking about the trunk and door being open which generated my response. All the instructions I have ever seen call for all fobs to be programed at the same time.
Are you saying that a single fob can be programed that way by 'back door programing'?
Old Apr 9, 2009 | 08:32 AM
Brutal's Avatar
There are differences on some models for back door programming. Some doors and trunk open some not..i have a life other than memorizing the different models and requirements...but is doesnt matter if you have them open if not required, and yes you can program a single remote, ive done it for years, but keys you cant
Old Apr 9, 2009 | 12:16 PM
Karl's Avatar
Thanks Brutal.
I am trying that as we speak. But I must be honest I am struggling keeping my left foot on the ground. I assume this is because I am in England and therefore sitting on the "wrong" side of the car. I will keep trying but my neighbours are now looking at me a bit strange.
Karl.
Old Apr 9, 2009 | 12:29 PM
Brutal's Avatar
Youre on the right side of the car, then use your right foot
Old Apr 12, 2009 | 04:33 AM
meirion's Avatar
Default key fob programming
Hi,
Does the headlight flashing method work for an x350?
Old Apr 12, 2009 | 07:08 AM
Brutal's Avatar
Originally Posted by meirion
Hi,
no.
drivers door closed.....
foot on brake....
radio off...
and while holding you left ear lobe with your left hand(this all switches to the right if youre on the OTHER side of the pond) switch the ignition on/off quickly 4-5 times till you get a chime for being in program or learn mode. remove key hit the disarm on each remote then reinsert 1 key and turn igition on then off.
take out key and hit remote (press the buttons ) to verify and your done...
Note...if it doesnt work the first time....try moving the seat to the closest seating position to the steering wheel....be sure and tilt the steering wheel up first if youre a food lover...
Old Apr 30, 2009 | 01:48 PM
Gus's Avatar
Gus
I had an intermittent problem with my remote. So, I elected to take it apart to see why. What I found is that it just needed cleaning. You can go to my page to see what I found and how I cleaned it.
Good Luck!
Gus
Old Sep 8, 2009 | 09:32 PM
Robscountach's Avatar
Isn't this also how you perform the DUI test in Germany ?
(for anybody who remembers "The Man With Two Brains" - Steve Martin)
Old Sep 10, 2009 | 05:35 PM
BadDog's Avatar
Default New Key fob programming
I was thinking of getting a second key fob for convenience. If I purchase a new/used key fob off of ebay (for example) can I program it for my XK8/XKR using this method, or does it have to be the original key fob from the manufacturer in order for this process to work?
Old Sep 10, 2009 | 06:42 PM
test point's Avatar
While I am sure that a little elf did not create the Jaguar FOB at a magical work bench in a secret part of a Jaguar factory, I am sure that finding a FOB with the correct part number on the back will make programming a lot easier.
The part number MUST match.
Bought them off eBay for less than $20, sold them for more than $60. All worked.
Dagny
Jun 11, 2024 01:06 PM
peterg19
Feb 10, 2023 09:02 PM
mbergen
Oct 23, 2019 10:26 PM
speacock
Sep 10, 2015 12:14 AM
skadmiri1
Sep 9, 2015 11:27 AM
