Both banks lean P0172 and P0174 stalls at idle
Old 01-09-2012, 01:51 PM
drun's Avatar
Default Both banks lean P0172 and P0174 stalls at idle
I tried cleaning the mass air flow sensor twice, looked for a leak between the butterfly and the MAF, idle smoothes out when I spray carb cleaner under intake plenum on passenger side. Could it be a hose under there or the yellow oval plenum gaskets? maybe MAF bad?
Old 01-09-2012, 02:08 PM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
Hope the following link helps you out.
Jaguar vacuum leak p0171 p0174 s-type 3.0 <-- THANK YOU Gus!
The following 2 users liked this post by joycesjag:
drun (01-29-2012), Gus (01-16-2012)
Old 01-09-2012, 03:24 PM
drun's Avatar
Thanks, this is the area I sprayed the carb spray into and the idle improved while doing it. I already replaced the spark plugs and coils so I've been down in there before and was afraid I'd be back this time.
Oh well and thanks again for the great info!
Old 01-09-2012, 03:44 PM
joycesjag's Avatar
I would replace the upper and lower intake gaskets as well.
drun (01-16-2012)
Old 01-09-2012, 09:01 PM
bfsgross's Avatar
Good job Rick.
Old 01-10-2012, 07:57 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
An actual stall on that era & engine will almost always be an air leak and again almost always the PCV hose elbow. Yeah.... you're gonna be in there again!
Old 01-16-2012, 04:24 PM
drun's Avatar
Got it back together last night and drove it around the block. No more vacuum leaks/codes, but now I have a leaking injector at the rail. I bought new o-rings but the parts place only had 2 packs of 4, so I just replaced the bottoms, (gambled and lost). It's raining today so tomorrow I'll get back in there to replace $5 worth of parts...
Old 01-16-2012, 08:41 PM
bfsgross's Avatar
At least you did it by yourself and you're almost there. Good job!
drun (01-29-2012)
Old 01-16-2012, 09:05 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Kudos to you!
Old 01-29-2012, 08:43 PM
drun's Avatar
I changed the injector o-rings the next day and it runs like a top.
No more leaking oil onto the right exhaust manifold (stinking air conditioner smell) either as I took the suggestion and changed the Intake manifold tuning valve o-rings and cabin air filter too.
Old 01-29-2012, 08:51 PM
joycesjag's Avatar
Congrats, glad we could help!
workworkwork
10-23-2015 10:26 AM
tomkilner
10-09-2015 07:10 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
10-05-2015 04:05 PM
inactualis
10-02-2015 11:13 AM
Glenn Barickman
10-01-2015 04:09 PM
Quick Reply: Both banks lean P0172 and P0174 stalls at idle
