How to programme key fob for S Type
I'm a real novice with S Type or any type Jaguars but I'd like to share my little bit of success here.
Bought 1999 S Type with key fobs not working. Googled problem and found solution on fixya. It may well be on this site too but it actually worked for me. Here it is and it worked first time.
"Turn ignitiion on/off 8 times (allow all functions to stabilise) after the 9th on - press a button on both remote fobs. then turn ignition off. Use good remote to lock and then try new remote to unlock/lock. sometimes it works first time - sometimes you have to repeat actions. good luck."
Hope this helps someone out there.
Chris
Chris
Received 6,253 Likes
Right perhaps I used the wrong wording ie programme maybe sync instead. All I know is I bought this 1999 S Type and the fobs that came with the car would not work at all so I was unlocking car with key only. So with these old existing fobs I did the on/off 8 times procedure and now they work.
Chris
Chris
