Hub nut
Its not the wheel nuts thanks the hub nut that goes on the end of the drive shaft and hold the bearing , hub and drive shaft to the car.
Also is it ment to be a nut with a collapsible edge or a locking washer thing or just alot for force to stop it undoing itself.
However, 32mm as stated by spielnicht - sounds right for the Hub Nut.
(dunno about the economics of his rattle-gun though)
Have a nice day.....
fix it (10-19-2012)
I think the guy i brought the car from 1.5 months ago has put new bearing on and did NOT do the nut up tight enough.
The problem im going to have is making 200+ nm of torque to do the new one up with out air tools. And lastly thank you for the answer.
Nope, I'm not at all sold on the rattle-gun approach.
Good luck with it anyways....
