Sponsored by: DashLynx
Can we talk about seat wear
Old 07-27-2014, 08:11 PM
jagtoes's Avatar
Received 1,836 Likes on 1,231 Posts
Default Can we talk about seat wear
I don't have any visible wear yet but based on the way I get in and out of the car I suspect in time the bolster will wear. Has anyone started to see this and is it reduced if you do a leather treatment once a month. Having the charcoal interior I would think it would show at some point in time. I only have 8K miles on the car but just wanted to see if this leather wears better then some of my other cars.
Old 07-27-2014, 08:26 PM
BruceTheQuail's Avatar
Received 1,270 Likes on 875 Posts
Yes, mine (charcoal) is worn along the seam of the bolster. It had fairly high mileage when I got it (about 25000 miles in under 3 years) and it was like that. Essentially the dye/outer coating is abraded off. It isn't all that noticeable (maybe 3 inches), but it isn't perfect. My first XF (ivory leather) wore along the seam in the bottom centre of the seat, probably from my belt rubbing it.
Old 07-27-2014, 10:17 PM
Stuart S's Avatar
Received 6,141 Likes on 3,384 Posts
You may be able to repair/restore the worn leather surface yourself.
See this thread: https://www.jaguarforums.com/forum/x...-camel-102779/
Here's the link to the Dynamix product recommended by WhiteXKR in the above thread: JAGUAR LEATHER DYES
A small area of the left side of my driver's seat bolster is beginning to show some wear, so I thought I'd touch it up. I just ordered the 30ml bottle and will let you know how it works.
Stuart
The following 6 users liked this post by Stuart S:
bobdr1 (07-28-2014), BruceTheQuail (07-27-2014), jagtoes (07-28-2014), Jffcurt (07-28-2014), MaximA (07-28-2014), richzak (07-28-2014) and 1 others liked this post. (Show less...)
Old 07-27-2014, 11:11 PM
tberg's Avatar
Received 2,541 Likes on 1,412 Posts
Jagtoes,
Mine in the same color had some wear in the same area. Last week, I simply took some liquid black shoe polish (as I do about every 6 months in my 2002XKR convertible), spread it around the area and then wiped off with a clean towel. Virtually invisible now.
The following 5 users liked this post by tberg:
bobdr1 (07-28-2014), jagtoes (07-28-2014), Jffcurt (07-28-2014), MaximA (07-28-2014), mosesbotbol (07-28-2014)
Old 07-28-2014, 06:07 AM
mosesbotbol's Avatar
Received 1,197 Likes on 931 Posts
Originally Posted by tberg
Jagtoes,
That's an old trick, but still useful today. I have very minimal wear on the outer bolster on the driver's seat. Not enough to deter from the car, but you can see a difference between driver and passenger in that regard. I do leather treatment monthly. Bigger culprit on my interior is jeans dye transfer and around the doors the leather is easy to nick. Over all, my interior still looks amazing. I use a custom fitted sun screen whenever the car will be parked outside for more than an hour.
Whomever ends up with my car is going to very lucky. I put 100+ hours a year into washing and detailing.
Old 07-28-2014, 07:40 AM
ddsski's Avatar
Just buy the proper dye from Leatherique and do it right. Very easy.
The following 2 users liked this post by ddsski:
bobdr1 (07-28-2014), MaximA (07-28-2014)
Old 07-28-2014, 08:37 AM
MaximA's Avatar
Didn't realize Leatherique made dyes as well, thats definitely the way I would go.
Old 07-28-2014, 03:29 PM
Ngarara's Avatar
Received 1,122 Likes on 795 Posts
I can recommend the Dynamix product - more like a thin plastic paint than a dye. I used it to restore the driver's seat on my XK8 before I sold it; the side bolster was very worn, but the paint brought it back to almost the original finish. It was slightly more matt, but I think I could have made it a bit shinier with an appropriate polish.
GordoCatCar
01-02-2017 01:10 PM
42Ajd
12-30-2015 09:45 AM
Col. Sandurz
09-28-2015 12:49 PM
42Ajd
09-21-2015 07:37 PM
Clamdigger
09-12-2015 03:43 PM
Quick Reply: Can we talk about seat wear
