Open trunk with Dead Battery
Old 12-05-2010, 07:38 PM
jrelrod's Avatar
Default Open trunk with Dead Battery
I have a 2000 XKR with a completely dead battery. Since the battery is dead I can't use the trunk latch release button to get into the trunk to charge the battery. There is no key hole. How can I open the trunk? Is there a release cable somewhere in the car?
Old 12-05-2010, 07:44 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
There is a keyhole!
Look for the 'XKR' logo at the back of the car on the right of the trunk.
There is a keyhole right smack in the middle between the 'X' and the 'K'.
Voila!
The following 2 users liked this post by WhiteXKR:
dan314 (02-26-2015), Jannxj8 (04-09-2014)
Old 12-05-2010, 08:22 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Old 12-22-2010, 05:37 PM
sandlin's Avatar
Default Dead Battery --Can't get trunk open to charge it!!
I have a 1998 Vanden Plas. Battery is completely dead. I tried to use the key to open the trunk, but must have hit the valet key before battery died. Is there a place in the engine to charge the battery---a positive terminal somewhere? Don't think I can use a voltage meter to check since battery is completely dead. Any help is greatly appreciated!!!!
Old 12-22-2010, 05:42 PM
Gus's Avatar
Gus
Gus is offline
Yes if you look at the link above and if that fails you may have another option.
Old 12-23-2010, 09:24 AM
Leedsman's Avatar
I read on this website some enterprizing geezer had crawled under his car and used the heavy-current terminal on the alternator (or was it the starter motor?) which is wired straight to the battery in order to put some +12volt onto the system to open the boot/trunk. If there is a superfuse in the heavy wiring somewhere, and it's ruptured, then that won't work however. Worth a try though?
Leedsman.
Old 12-23-2010, 10:08 AM
sandlin's Avatar
Smile How to charge a dead battery through engine compartment
Thanks everyone!! I called the jaguar shop I use and they let me in on how to charge the battery through the engine compartment! Next to each of the two fuse boxes in the engine compartment are rubber grommets that cover positive terminals (that lead to the fuse boxes). They are NOT marked, but covered by rubber grommets. Hook the positive of the battery charger there and the negative to the metal of the car body and it's as simple as that! Worked like a charm. Battery is charging now.
Old 12-23-2010, 02:16 PM
Gus's Avatar
Gus
Gus is offline
Yes I know. My page shows you the locations under the hood for xj6 & xk8. Sorry I guess I did not make myself clear.
Old 12-30-2012, 03:38 PM
Swagga's Avatar
Does anyone know how to recharge the battery through the engine compartment for a 2007 XKR? I'm stuck overseas, my father has my car, can't get the rescue key to work and the battery is dead.
Old 12-30-2012, 03:48 PM
Gus's Avatar
Gus
Gus is offline
Old 02-12-2015, 12:59 PM
preziosr's Avatar
Originally Posted by WhiteXKR
There is a keyhole!
Voila!
Thanks very much. I could've looked forever and never found it.
Old 02-12-2015, 08:00 PM
brantman's Avatar
If everything is locked up and the battery is dead, you can attach a battery charger to the starter positive side and ground the negative anywhere. This will put some juice flowing to the battery. You can then pop the door/trunk and start it up. Of course, that only works if you have somewhere to plug in the charger. (Jumper cables should do the same thing.)
Old 02-26-2015, 02:17 PM
dan314's Avatar
Thanks to WhiteXKR.
Old 05-08-2018, 08:05 PM
Lucasjaguar's Avatar
Hello i have a jaguar xk8 1997 and the trunk dont open. A change sensor becouse there was a sign in the dash that said trunk open. So i solve that problem. But the thing is that the trunk still not open when i press the boton. When i press the boton the trunk make a noise of opening but nothing happen. Please somone can help me
Old 05-08-2018, 08:40 PM
Jon89's Avatar
Received 4,276 Likes on 2,813 Posts
Use your key to open the trunk. The key insertion hole can be difficult to see, but if you look hard enough you will find it in the chrome trunk emblem....
Old 05-09-2018, 02:16 AM
03 XKR's Avatar
I am not sure about the '97 model, but I would guess that it has an emergency release handle in the trunk behind the carpet below the brake light on the passenger's side as my 2003 does. It is a glow in the dark 'T' handle connected to a stiff wire that runs through a hole in the bottom of the latch and when pulled, manually releases the trunk latch in case someone gets locked in the trunk. On mine, the 'T' handle bound up in the carpet and plastic trim, which did not allow it to move, stiff wire, and kept the latch from releasing. I had to hold the key turned and open the lid because the bound wire would close the latch as soon as I let go of the key, another time it kept the latch from closing as it was bound up in the opposite direction.
Old 05-09-2018, 02:59 AM
dibbit's Avatar
I wonder if that is region or year specific, because I don't have one of those on my UK spec 2001 XKR.
Dagny
07-20-2020 05:39 AM
mbergen
10-23-2019 10:26 PM
99xk8guy
09-21-2019 07:34 PM
dsnyder586
04-04-2019 02:38 PM
al_roethlisberger
09-09-2015 09:14 PM
Quick Reply: Open trunk with Dead Battery
