E type ( XK-E ) 1961 - 1975
seat rollers xke series 11
Old Feb 10, 2015 | 03:16 PM
markxke's Avatar
Question seat rollers xke series 11
Hi im new to the e-type. Need to replace the seat rollers on my 1970 e-type ots. Not sure how to place the rollers in the track and then slide the tracks back together. Thanks Mark
Old Feb 10, 2015 | 09:08 PM
vrracing's Avatar
I havent messed with my seats yet but I would suggest taking a look at the Bentley manual, the XKSUnlimited and SNG Barrett catalogs.
The cars are very simple so some study should show fasteners or detentes that keep everything from falling apart.
Old Feb 11, 2015 | 07:54 AM
SNG Barratt USA's Avatar
Former Sponsor
We sell them complete if it helps?
www.sngbarratt.com/CatalogueProducts.aspx?m=11&c=585&s=17240&a=17253
Old Feb 13, 2015 | 04:43 PM
Fraser Mitchell's Avatar
Each slider should have four ***** (as in a ball bearing) to separate the two parts of the slider, and provide the sliding action with minimal friction. As it was the 80s, I can't remember the detail but essentially one uses grease to hold the ***** in place while assembling. The grease is an essential part of assembling the slides, anyway. There are a couple of split, or spring pins to hold the thing together when assembling.
Sorry I can't tell you more, it is too long ago, and memory fades. Did you not disassemble them yourself ?
Old Mar 21, 2015 | 06:33 PM
felinecat's Avatar
The nylon little drums that are supposed to make the seats slide back and forth easy on an xke are self-undoing ! the nylon rollers/drums are a snug fit in between the seat slider tracks so any dirt or rust tends to make the seat more diffcult to slide Soooo
I removed the rollers and greased the slider tracks and they work like a charm without them ! You can hammer one track over the other to roll over the nylon drums to get them out.
Old Mar 26, 2015 | 11:18 AM
Jagrick's Avatar
No ball bearings in series II, nylon drums. Punch up dimple and then note position of drum on upper and lower tracks as they come out. Clean and reverse assembly and repunch dimple to keep rollers from coming out. Series I had metal rollers that has O-rings in grooves.
Old Apr 8, 2015 | 03:40 PM
markxke's Avatar
Hi jagrick. Thanks I have my rollers out not sure how to replace. Not sure what you mean by punch up dimple.
Old Apr 9, 2015 | 11:00 AM
Jagrick's Avatar
Default seat track
I will grab mine and look this weekend. I have disassembled both series 1 and series 1.5 runners, post the info, photos here once I get them-Rick
Jose
Dec 18, 2021 08:16 AM
Rivguy
Dec 4, 2020 07:55 AM
SCMike
Sep 22, 2015 07:34 PM
etypo
E type ( XK-E )
Sep 22, 2015 10:33 AM
Clamdigger
Sep 12, 2015 03:43 PM
