E type ( XK-E ) 1961 - 1975
SU HD8 Carb leaking
Old May 15, 2016 | 08:58 PM
Lagonia's Avatar
Default SU HD8 Carb leaking
One of my three carbs on my 3.8L engine is leaking from the bottom. The engine is a bit rough but when it warms up is as smooth as glass. Would a rebuild fix this issue? I can find my way on the SII, SIII and X350 engines but the carb engines are new to me.
Is there a carburetor rebuild kit that is better than any others? Sources? Anything in particular I need to watch out for?
Thanx.
Old May 15, 2016 | 09:15 PM
motorcarman's Avatar
Sounds like the diaphragm split and is leaking. The cold start enrichment on the HD8 (Horizontal draught_Diaphragm 8X1/4 inch) is activated by lowering the jet and the flexible diaphragm can split/leak.
New jets can be installed and centered. I would replace all the jets. If one failed, the other 2 can not be far behind. Check the needles for wear.
Strombergs are a whole 'nuther animal'.
bob
Old May 17, 2016 | 08:05 AM
Lagonia's Avatar
Thanx for the reply Bob.
I ordered the carb rebuild kits from SNGBarratt and I am in the process of doing my research before I tackle this. Two things come up consistently:
- Needle centering
- Carb syncronizing
On the carb syncronization, there seem to be a couple of tools out there that might help:
http://static.summitracing.com/globa...s/EDL-4025.pdf
SU Carburetor Tool Kit, New - Rogers Motors
Not horribly expensive but the question is: Is anyone better than the other? Or is there yet a better tool out there?
Old May 17, 2016 | 03:08 PM
Mr. Barry's Avatar
I'm a little confused...I am pretty familiar with S.U. carbs, and don't remember a diaphragm in the carbs....
ZS carbs do have a diaphragm...
In any event the Rogers (reproduction) tuning kit is the one you will want, along with a Unisyn synchonizer...Both inexpensive, and very useful.
Very simple tools, that will make jet centering and synching very easy.
Edward
Old May 18, 2016 | 08:31 AM
Jagrick's Avatar
Rubber diaphragm supports metering part that needle goes into. WHen split does leak. A centering tool is available and not that expensive. Rebuild is not bad unless throttle shafts need reamed and then a little more technical.
Old May 18, 2016 | 11:38 AM
Mr. Barry's Avatar
Do you have a SNG part #? Are you talking about the jet assembly???
Sorry, never heard that referred to as a diaphragm.
Edward
Old May 18, 2016 | 11:55 AM
Lagonia's Avatar
Can you elaborate more on this "centering tool"?
Thanx.
Old May 18, 2016 | 08:26 PM
Lagonia's Avatar
I shall be having fun this weekend rebuilding by first set of SU HD8 carburetters. Kits arrived from SNGBarratt
Old May 18, 2016 | 08:35 PM
Edward
From wikipedia............
The carburettor identification is made by letter prefix which indicates the float type:
"H": in which the float bowl has an arm cast into its base, which mounts to the bottom of the carburetor with a hollow bolt or banjo fitting. Fuel passes through the arm into the carburetor body. The bolt attaches to the carburetor body just behind the main jet assembly.
"HD": the float bowl mounts with its arm fastening directly below, and concentric with, the main jet. The arm has a flange that fastens with 4 screws to the bottom of the carburetor, and sealed with a rubber diaphragm integral with the main jet.
"HS": the float bowl is rigidly mounted to the carburetor body, but fuel is transferred by a separate external flexible line.
"HIF": the float bowl is horizontal and integral (hence the name).
"HV", "OM" and "KIF" types also exist but were less commonly employed.[5]
The Imperial sizes include 1-1/8", 1-1/4", 1-1/2", 1-3/4", 1-7/8", and 2", although not every type (H, HD, HS, HIF) was offered in every size.
Old May 19, 2016 | 08:37 PM
Lagonia's Avatar
The shop manual strongly suggests that the carbs should not be removed from their respective intake manifolds but rather be removed along with them. There seems to be a concern about the proper fit of the o-rings around the spacer if the carburetters are removed and re-installed in the engine if the intake manifolds remain in the engine.
Is this a valid concern?
Old May 20, 2016 | 11:53 AM
Mr. Barry's Avatar
I would follow the manual, here...Not always the case, but I think the manual is pretty clear
on this one.
Edward
Old May 21, 2016 | 09:33 PM
RedRider48's Avatar
Thanx.
I hazard to high jack another Jag brother's response, however, had these readily available......
The little "doodad" next to the vinyl pouch is part of the tool kit and is the centering tool. Once the jet is in place, leave it slightly loose. Then, you insert the small diameter end into the needle seat. When you lower the "bell" it will/should self-center the jet, insuring there is no binding on the needle when it is re-installed. Tighten the jet with the centering tool in the jet, this insures the jet doesn't move. The needle needs to move within the jet without binding. As shown, I own a number of different sync tools including the early version with the lifting rods and the fuel level adjusting rod as seen in the previous link. By far the best is the one on the right of this photo. Although, the Unison is a dar good example too.
Good Luck...
Attached Thumbnails SU HD8 Carb leaking-img_2714.jpg   SU HD8 Carb leaking-img_2715.jpg   SU HD8 Carb leaking-img_2716.jpg
Old May 23, 2016 | 09:28 PM
Lagonia's Avatar
Default Carburetters are out!
Time to start playing around! Nothing than rebuilding something totally foreign and unknown for the first time!!
Old May 24, 2016 | 03:42 AM
bkeats's Avatar
Hello Lagonia,
With the cleaning process, don't get carried and use any abrasive, or any agent that will change the fit of the Air Piston in its Bore (clearance). Like a Stromberg 175 CD carburetor, the SU is a Constant Depression type carburetor, but unlike the Stromberg, it relies on the fit of the Piston to maintain the Vacuum in the chamber. The Stromberg uses a diaphragm, so is more forgiving in this regard.
Regards,
Brent
Old May 26, 2016 | 06:02 PM
Lagonia's Avatar
Default My first SU carb dis assembly and mild cleaning
This is pure elegant simplicity compared to a 4-barrel Quadrajet
I can't claim that I know what I'm doing but I am not one to shy away from, what appears to be, a manageable challenge.
Old May 26, 2016 | 06:53 PM
plums's Avatar
Now isn't this more fun than flashing a module?
Old May 26, 2016 | 08:15 PM
Lagonia's Avatar
Unquestionably!
Old May 26, 2016 | 08:42 PM
Lagonia's Avatar
RedRider48, I did get the tool you mentioned above. I CANNOT get the centering pin to slide into the jet bearing. It gets stuck. Would I have an off size centering pin or am I missing something?
Also, I cannot get the jet needle off the piston, period! Is there a trick to removing it? The lock screw is out of course...
Old May 26, 2016 | 10:52 PM
RedRider48's Avatar
Hmmm? Doesn't that s_____k! That needle should pull out. Can you get us a OD of the centering pin? Mine measures .0248
Old May 27, 2016 | 08:33 AM
Lagonia's Avatar
So I was able to pull the needle out by soaking it with PB Blaster and then twisting the piston with the needle securely (but gently) held by the vice with vinyl protectors.
Now on the centering pin - I am measuring 0.251", 0.003" thicker than yours. That does explain it.
Thank you for posting the pics!
