Exterior Talk about your rims, bodykits, and other exterior mods here.
Rims Advise
Old Jan 30, 2009 | 02:32 PM
GottheJAG's Avatar
Default Rims Advise
I just bought a 1992 Jag and was wondering what sizes of rims can I fit on the car? Also do you know what the offset or bolt pattern need so I can find some rims to put on my Jag. Thanks
Old Jan 30, 2009 | 03:14 PM
super_jag's Avatar
Default RE: Rims Advise
what king of Jag
Old Jan 30, 2009 | 04:05 PM
GottheJAG's Avatar
Its an XL6
Old Jan 30, 2009 | 08:48 PM
JagtechOhio's Avatar
Here's some available choices, both 16" and direct fit on your XJ6
1994 Jaguar Kiwi wheels
1995-1997 Jaguardimple wheels.
[IMG]local://upfiles/3394/4CF218D0D2EC4CCDB2B3B458AEF27E4B.jpg[/IMG]
[IMG]local://upfiles/3394/18CD23BBD6404C049A76B9ACE07FECD9.jpg[/IMG]
[IMG]local://upfiles/3394/85B035D28D0844ECBA80DBD5E0B903FC.jpg[/IMG]
Old Jan 31, 2009 | 03:45 AM
Cadillac's Avatar
You may also try 1993-94 XJ12 wheels , they're 16"
[IMG]local://upfiles/1277/5F1ACAECAB3540FEBAA66EBDBE285622.jpg[/IMG]
and see my post at this thread :
https://www.jaguarforums.com/m_90068/tm.htm
Old Jan 31, 2009 | 09:59 AM
Hi Caddy,
I have a set of those 16" Lattice, I thought they were for a Le Mans edition XJS. They were factory XJ12 too? Canada or Europe? Never saw them in U.S.
Old Jan 31, 2009 | 11:07 AM
Doug's Avatar
Really?
I've seen quite a few XJ40/V12s with the 16" lattice wheels here in the USA. In fact I thought they were standard issue for that car <shrug>
Old Jan 31, 2009 | 11:26 AM
GottheJAG's Avatar
I meant like as in bigger wheels, whats the biggest I can fit, I wanna go bigger. Will 20 or 22's fit? Just curious on fitment
Old Jan 31, 2009 | 11:50 AM
Can't help you, that's not the way I roll.
Old Jan 31, 2009 | 11:58 AM
Doug's Avatar
ORIGINAL: JagtechOhio
What he said
Old Jan 31, 2009 | 01:04 PM
jaggachafen's Avatar
20 inch will fit take a look at my xj6 here
http://www.garaget.org/?car=123236
did some mods though but the rims where wide and whith big tuires if you use 8,5x20 whith 225/30/20 you wont have a slitest issue
Look at dp motorsports for wheels
Old Mar 9, 2009 | 09:07 PM
boostedb18's Avatar
jaggachafen What wheels are those? They are so bad ***!!!!Give them to me!!!! lol Seriously could ya tell me what they are so i can copy you
Old Mar 22, 2009 | 12:52 PM
Maja216's Avatar
I would advise you to go to reputable tire shop and they will be able to tell you how big you can go. The rule is simple the total diameter of the wheel and tire should stay about the same all you are changing is the tire to wheel ratio, meaning more wheel less tire. I would also tell you to watch the with of the new wheels as wider wheels can cause rubbing in the wheel wells and possibly the outer fender. I hope this helps, keep us posted
Old Nov 30, 2009 | 06:23 PM
jimmycruz99xjr's Avatar
Former Sponsor
i suggest 20's to be safe your wheels should be no bigger than 20x9.5 but you can also use 8.5 just to be safe your tires should be 255/35/20 in the front and the rears 285/30/20
or you can do 235/35/20 all the way around.
robbing
Mar 5, 2024 10:51 AM
Larry-Cleveland
Feb 9, 2019 03:17 PM
Marque
Oct 11, 2015 05:59 PM
Marque
Sep 27, 2015 10:28 PM
