F-Pace (X761) / C-X17 2016 - Onwards
Disengage auto stop/start 2017 (& Later) F-Pace
Old Aug 10, 2016 | 12:14 PM
Spesh's Avatar
Default Disengage auto stop/start 2017 (& Later) F-Pace
The objective is to unplug one plug from the voltage quality module located in the right pillar of the 2017 F-Pace that effectively disengages the auto stop/start feature.
1. Remove fuse cover and right rear tie-down.
2. Carefully pull back the weather strip along the right pillar.
3. Pull carpet lining down and out in order to expose inside of pillar.
4. You will now see the module. You may need a flashlight. In order to get back to the start/stop plug, you need to first remove the larger plug that is blocking access to the smaller plug behind it.
5. Unplug and secure stop/start plug. Re-attach large plug.
Old Aug 11, 2016 | 04:46 AM
Jaguilar's Avatar
Thank you for sharing! I'm going to try it out today.
Old Aug 11, 2016 | 08:17 PM
MKenM's Avatar
Very interesting. How difficult is it to remove and reinstall the weather strip?
Old Aug 12, 2016 | 07:45 AM
Spesh's Avatar
MKenM, the weatherstrip is easy; just pull it off the pillar area. You do not have to remove the entire strip. The tie-down was a bit tricky; you have to pull the bottom out, then twist it and pull it out.
Old Aug 12, 2016 | 08:38 AM
MGluck's Avatar
Given the location of the module, is it absolutely necessary to remove the tie down. Can you not simply bend back the carpeting to reveal the module?
Old Aug 12, 2016 | 01:52 PM
Spesh's Avatar
It is tight even with the tie down removed. You can try. My friend who helped me had the tie-down removed in seconds so it is not a big deal as long as you know how to pull it out. I just did not see exactly how he did it, and being plastic, one does not want to break it.
Old Aug 12, 2016 | 03:12 PM
Jaguilar's Avatar
Greetings,
Well, I did this today and it really works as advertised.
Best regards
Old Aug 14, 2016 | 06:42 AM
UalCapt's Avatar
Thanks for the great post! Does this mod cause any warning lights to be displayed, or any error codes?
Old Aug 14, 2016 | 08:57 AM
Spesh's Avatar
No. Only when you press the auto start button, there is a brief message that says, "auto stop/start fault" for about 2 seconds.
Old Aug 14, 2016 | 12:40 PM
Mulmur's Avatar
On my 2015 Ftype R its a seperate battery so its easy... not sure if my XE will have the same setup as the F Pace.
Lawrence
Old Aug 15, 2016 | 09:25 AM
4Holer's Avatar
Thank you so much! Worked perfectly - Peace of Mind! Life is good.
Old Aug 16, 2016 | 06:33 PM
tcfpace-pa's Avatar
Guys, I did this on my F-Pace FE and it's working fine just as advertised here. A couple of suggestions though. I removed both the hanging hook to the right of the fuse box opening and the metal tie down hook (allen key) on the boot floor. That made it much easier to get at the module. I also had to remove both of the big plugs to easily get to the little one that needs to be removed to disable the Auto Start.
on the hanging plastic hook however, it is actually has one of the press/pull fasteners at the top. To remove it, look closely at the top of the hook, you'll see a little rectangle, using your fingernails or two small flat blade screwdrivers pull that rectangle towards you. That will release pressure on the fastener and allow you to very easily remove it. Then to put it back simply line up the openings push it in and then push the rectangle back in.
Old Aug 19, 2016 | 12:32 PM
FpaceJK's Avatar
Can someone confirm 100% that this link only disables the Start Stop Function?
You may not have needed or have other items that this may affect is why I ask and do not want to do this mod to find it also turns off something else that no one as yet has had to use or has fitted to there cars.
Thank you.
Old Aug 19, 2016 | 02:16 PM
Spesh's Avatar
I have had mine unplugged for almost 3 weeks with no other items affected. When starting the ignition, the auto start/stop light indicates that the feature is off which is the objective of this post. When pushing the manual override button located on the middle console, a brief message appears that there is an "auto start/stop fault". That is all I have observed.
Old Aug 19, 2016 | 02:52 PM
FpaceJK's Avatar
I do not understand why they just do not have it set that when its off it stays off till you press the button and then its on.
It also annoys me that you when you set your car to dynamic and turn the car off then next time its back to standard and you have to select dynamic.
Why can they just not remember the last setting, it can not be that hard.
Old Aug 19, 2016 | 03:23 PM
Spesh's Avatar
I could not agree with you more.
Old Oct 1, 2016 | 06:54 AM
UalCapt's Avatar
Just wanted say thanks for posting this ... Works like a charm!
Old Nov 29, 2016 | 12:34 PM
ultraman206's Avatar
Thanks for posting this! I just did this yesterday. Wife couldn't be happier!
It took me a little longer as I couldn't pull the carpet "down and out" following the instructions. I ended up removing all the fasteners on that carpet panel, took the floor cover, the spare, the jack, and the scuff plate out and just lifted the carpet panel up to access it. I didn't have to mess with the weather strip.
Old Nov 29, 2016 | 03:42 PM
BigCat09's Avatar
Question
Lawrence
I need to find this location on my new XE as this is annoying!
I plan to take it in for service as this is auto on even when your in Dynamic mode which is a joke as no other Jag has this on when in Dynamic mode.
Can you F-Pace guys tell us if yours is on in Dynamic mode as well please?
Old Feb 4, 2017 | 06:12 PM
DPK's Avatar
DPK
Great post Spesh...
As my luck would have it..I went about tackling this project to disabling the this Stupid Auto-Start/stop feature...I followed the great instructions and guess what?..NO friggin' MODULE...anywhere, I even looked under the spare tire and battery..Nothing!...So Back to square one, as I have no clue of where else to look for this damn module..
Anybody have any other ideas of where to look for it?..My build date is May, 2016...
Thanks for any help
