F-Pace (X761) / C-X17 2016 - Onwards
Panoramic roof leak
Old Oct 8, 2024 | 09:06 AM
kowal.lukas88's Avatar
Default Panoramic roof leak
After heavy rains I had some water on the headlining.
Recently there was a pool of water in the passenger foot well.
I have decided to track down the leak.
After removing headlining and spraying considerable amount of water on the sunroof I have found this which is probably source of the leak.
Does anyone know what is this outlet for? I feel like there should be some pipe which takes the water to drainage etc.
This is right above passenger seat
Old Oct 8, 2024 | 10:39 AM
2018XF25T's Avatar
More likely a clog in drainage roof system. Try cleaning it and afterwards, close the sunroof and run a water through it. See if that fixes the problem. On this thread at the XJ forum, there is a past discussion how to clean it.
https://www.jaguarforums.com/forum/x...-lines-169307/
Old Oct 8, 2024 | 11:09 AM
Thanks for reply.
I have tired cleaning seals and around the sunroof, but I cannot find any drain outlets it seems the water is just running under the roofbars.
Are you sure there are outlets in F-Pace and if so where can I find them, I have really tired looking.
Old Oct 8, 2024 | 12:28 PM
2018XF25T's Avatar
Tthe reason you can't find the holes could be the holes are blocked with dirt or other debri. Get a weed wacker string or a thin electrical wire and try poking on the 4 sides of the sunroof. Read "Roverdude" comments on this forum
https://www.fpaceforum.com/threads/w...-inside.40257/
Old Aug 22, 2025 | 02:12 AM
Dilimake's Avatar
Default Water leakage
Did you finally manage to solve it? It would be very helpful if I could find out how you solved it because I have the same problem.
Old Sep 17, 2025 | 10:12 PM
Just Me's Avatar
Lightbulb FYI
Just an FYI, there are no panoramic roof drain holes on the F-Pace at all, and no drain hoses, just drainage channels, running off the back in front.
This was most likely, a roof rail, mounting stud seal leak.
Old Oct 29, 2025 | 04:54 PM
Dr.Andrew T's Avatar
Default f pace water in salon
Hi everyone. Please help. I was looking for the water drains, cleaned something, and now the water drains nicely into the wheel arch, but there’s a lot of water inside the cabin. I took down the headliner but couldn’t find any drain tubes.
File Type: mov
Old Oct 31, 2025 | 11:09 AM
Just Me's Avatar
Exclamation see above post
That's because there are no roof drain hoses on an F pace panoramic roof. see above post
JS NZ
Jan 29, 2024 01:15 PM
glencol
Mar 18, 2023 06:06 PM
paulsdunford
Feb 4, 2021 10:56 AM
Flappers
Oct 17, 2019 04:17 PM
user 2029223
19
Apr 12, 2011 04:40 PM
