Anybody else experiencing this?
Old Jul 6, 2016 | 03:52 PM
Steve Youn's Avatar
Default Anybody else experiencing this?
Hi everyone, anyone notice a slight mechanical / groaning sound when reversing out of a driveway? I have had the rear suspension insulator TSB performed and also a new strut installed on the rear drivers side to correct the well known "clunk" for 2013 - 2014 models. All is quiet and appropriately stiff now during normal driving. However, when I back out of my driveway every morning I hear a slight metallic noise coming from the rear of the car. The mechanic at my dealer mentioned that the active damper system on the V8S and R versions can make some sounds over speed bumps etc. Seems strange to me but normal driving is fine. Anybody ever noticed that?
Old Jul 6, 2016 | 04:57 PM
WhiteTardis's Avatar
-Emergency brake actuator releasing?
-Active Exhaust System solenoid?
Old Jul 6, 2016 | 06:31 PM
Steve Youn's Avatar
Definitely not the e-brake as I never engage it. Interesting thought on the active exhaust. Possible that the flaps are shifting when I back down over the curb? Doesn't seem to happen any other time than backing from my driveway onto the street. Will have the tech take a listen the next time I have her in for service. Thanks for the reply.
Old Jul 6, 2016 | 07:10 PM
Unhingd's Avatar
E-brake is automatically engaged on mine when I turn the engine off. I suspect yours too. Does the red "Park" light up in the display between the gauges when you shut down?
The groaning when you back up may be the brakes holding until the computer senses that you really mean to move, and then it releases automatically. You have to release the e-brake every time you start up and take off even if you never applied it.
Old Jul 7, 2016 | 12:01 AM
IronMike's Avatar
If so, it releases just as automatically as it engages itself. I rarely engage the E-Brake manually and even more rarely do I disengage it manually...
Parking on a relatively steep incline is the only time I consider using the E-brake.
Old Jul 7, 2016 | 12:15 AM
Holy F type's Avatar
I hear it aswell, mainly when i enter tall entrances while turning.
Old Jul 7, 2016 | 06:54 AM
Unhingd's Avatar
That be true. However, I can still feel a slight resistance before it disengages itself, so I'm in the habit of manually releasing it (when I remember). When I don't, if the car has been sitting awhile, the brakes will groan before the e-Brake fully releases itself.
Old Jul 7, 2016 | 06:38 PM
Uncle Fishbits's Avatar
Do you guys "ride" the clutch when reversing? I sure as hell do.
Old Jul 7, 2016 | 08:21 PM
Unhingd's Avatar
Only when I want to keep it under control. When I'm in Downingtown, PA racing Steve Andrews for shots of wisky, I'll use a fully engaged clutch.
teroks
Oct 2, 2022 04:38 PM
WayneinAus
Apr 23, 2016 12:49 AM
EZDriver
Apr 12, 2016 06:30 PM
domino_z
Apr 11, 2016 02:10 PM
Andi Baker
Apr 9, 2016 05:51 AM
