Bonnet vents
Old Jul 20, 2016 | 07:53 PM
Tally Ho's Avatar
Default Bonnet vents
Was the relocation of the bonnet vents aesthetic or functional? I noticed the 2016 up V8 cars have the vents set lower on the bonnet than the 2014-15 V8 cars. The V6 cars are all in the same location.
Old Jul 20, 2016 | 09:25 PM
Foosh's Avatar
The relocation was functional and necessary to accommodate the front transfer case for the AWD models, which required a higher engine mounting and different hood design. In the US, AWD is the only V8 available for sale. RWD V8R models, which are still available in other markets retain the 14-15 vent location and hood design.
V6 AWD models also have the same hood and vent location as the V8s.
Old Jul 20, 2016 | 09:27 PM
Unhingd's Avatar
I believe all the AWD cars have the louvers lower on the hood, even the V6 AWD cars
Old Jul 21, 2016 | 12:29 AM
Arne's Avatar
That is correct. I think it is because the engine sits a little higher in the AWD versions, so they had to change the hood slightly and move the louvers to make room.
Old Jul 21, 2016 | 04:12 PM
Tally Ho's Avatar
Thanks everyone. I thought there would be a simple explanation. It did not occur to me that the AWD system would change the engine height. Makes sense.
Old Jul 22, 2016 | 10:30 AM
enderle's Avatar
By the way, the vents don't actually do anything. On my V8S they are solid plastic. I swapped them for the open vents Mina Gallery sells but the engine cover pretty much blocks any air flow. Likely why the SVR doesn't have an engine cover.
Old Jul 22, 2016 | 11:29 AM
Arne's Avatar
I have the OEM carbon vents (delivered with the car when new) and they are open. Can't say anything about how effective they are in dissipating some of the engine heat, but I would think they help some.
Holding my hand over the vent clearly indicates some heat is lost that way.
Old Jul 22, 2016 | 02:09 PM
enderle's Avatar
Yes I too get a little bit of air but on my older XKR which doesn't have an engine cover there is a ton of air coming out. In fact I swapped the vents for the newer style which isn't as open and at Freeway speeds one blew off like it ejected flew well over the car which would have been funny had I not had them custom painted. There were glued and physically attached to the hood. It is kind of cool to see the engine cover's super charged emblem through the grill now though.
Old Jul 22, 2016 | 03:00 PM
Unhingd's Avatar
Dump the cover. It's increasing manifold temps by almost 20F.
Old Jul 22, 2016 | 04:25 PM
polarisnavyxj's Avatar
Any downside to removing cover?
Dirt, etc?
Old Jul 22, 2016 | 05:55 PM
Unhingd's Avatar
Dirt, etc?
I don't think so. It gets dusty in there no matter what. Just rinse it down occasionally (cold engine) and wipe the exposed surfaces.
Old Jul 24, 2016 | 07:57 PM
schraderade's Avatar
It'd be cool to replicate the single-slit vents but in tempered glass so there's still cooling but one could look through it to the supercharged engine cover labels.
I like the way Ferrari exposes parts of their mid mounted engine, or watches include a tourbillion window.
I doubt it's reasonable to manufacture something like this.
Old Jul 25, 2016 | 01:55 AM
What wrong with a grill?
you don't need a tempered glass window, just open mesh like the early base hood grills.
Old Jul 25, 2016 | 10:30 AM
lizzardo's Avatar
Dirt, etc?
The cover on mine already shows noticeable fading from sunlight through the mesh vents. I'm concerned about the plastic and rubber piping below it getting brittle.
I was toying with the idea of modifying the cover so the entire center is mesh; getting perhaps most of the benefit of removal while keeping the protection of the parts under the vent (and the supercharged logo).
Maybe someday. I need to get the car back first
Old Jul 25, 2016 | 11:31 AM
ShaunPA's Avatar
does anybody have a place to get the V6 vents from a dealer for cheap? want to change out the ones on my v8 and remove the engine cover as well.
Old Jul 25, 2016 | 11:57 AM
enderle's Avatar
Default Try E-Bay
They come up on e-bay every once in a while and Mina Gallery has metal mesh replacements which are pretty open. I believe they'll still paint to match as well if you like.
Old Jul 25, 2016 | 12:22 PM
I have a base mesh grills on my car. You can't see the detail very well.
The viewer is at an angle (unless he's standing on the hood!) so the mesh is not as see-through as you think.
Old Jul 25, 2016 | 01:21 PM
Unhingd's Avatar
Shaun, do you have the RWD V8?
Here are the part numbers: T2R9767, T2R9765 Left & Right respectively. Unbelievably expensive, but here's the cheapest place to find them: http://www.jaguarlasvegasparts.com/
Used on eBay would be a better bet when available, or you could offer to swap your V8 vent with a V6 owner on the forum.
Old Jul 25, 2016 | 01:50 PM
Mahjik's Avatar
The engine gets much hotter than anything the sun is going to do shinning through those vents. i.e. I wouldn't worry about it from a brittle standpoint...
Old Jul 26, 2016 | 07:32 AM
ShaunPA's Avatar
Here are the part numbers: T2R9767, T2R9765 Left & Right respectively. Unbelievably expensive, but here's the cheapest place to find them: Genuine Jaguar OEM Factory Parts sold at Wholesale Prices | Jaguar of Las Vegas
thanks! $165 a piece is expensive for what they are, but not too bad in the grand scheme of things. if ebay doesnt prove fruitful in the next 30-60 days i'll just go this route.
WhiteTardis
Jun 27, 2016 08:01 PM
Asdrewq
Jun 18, 2016 06:45 AM
philipa
Jun 8, 2016 07:41 AM
jagent
May 9, 2016 06:43 AM
Seth
May 4, 2016 12:52 AM
