Can't Open Trunk V8s
Old Dec 15, 2025 | 03:32 PM
ibrahimnetto's Avatar
Unhappy Can't Open Trunk V8s
Hello guys, I just got a big problem today: I can't open my F-Type V8s trunk anymore and/or plug a battery from the engine bay.
Short history - I took the battery off the car to charge it, and jumped the battery connectors together to do a hard/module reset by draining any residual charge from the capacitors.
Then I closed my trunk to not get dusty inside but forgot that it can only be opened electronically. Over the internet, people suggest to connect the battery in the engine bay, but that's not an option for me as the battery connectors on the trunk are jumped.
Anyone have any suggestions on how can I access the trunk and open it? This really ruined my day
Old Dec 15, 2025 | 04:46 PM
Carbuff2's Avatar
You aren't the only one to have suffered through this! Don't beat yourself up.
Start reading here:
https://www.jaguarforums.com/forum/f...2/#post2842903
Old Dec 15, 2025 | 04:49 PM
Vasara's Avatar
First at all: Modern vehicles have non-volatile memorys to store settins for faster start-up quite complicated systems. Therefore "jumping" battery terminal mainly only resets your clock. There are an "Vehicle Reset" command on diag tools reseting what is nessesary. (even that won´t reset all)
On XJ (x351) behind of rear seat is an connector for 12V to operate directly boot motor without powering up anything else on car. No idea if such added on F-Type.
Old Dec 15, 2025 | 04:50 PM
Carbuff2's Avatar
Another possibly easier way, is to release the boot-lid from underneath...
Posts 50 and 51 of the same Topic above.
Old Dec 15, 2025 | 06:51 PM
lizzardo's Avatar
This process will definitely reset the Battery Module, and is necessary if use of an OBDC device has left the system in a state where it will not go to sleep. This is really common when the diagnostic session has not been properly shut down, such as after emissions inspection.
Old Dec 16, 2025 | 01:56 PM
My brand-new battery is dying for no reason, and I didn't changed anything on the car, so I was assuming it might be related to the car shop not proper shutting down the OBC connection on my last car revision. That's why I tried, what many members suggest, to reset the computers by removing the battery and connecting both positive and negative together.
Old Dec 16, 2025 | 01:57 PM
Exactly, that's why I've connected positive & negative and removed the battery.
My mistake was to close the trunk to not get dusty inside.
Old Dec 17, 2025 | 09:33 AM
Carbuff2's Avatar
So did you get in?
Tell us your method..
Old Dec 28, 2025 | 11:09 PM
GraysonBrooks's Avatar
Spoiler
How did you resolve it?
bigbadorange
Mar 14, 2023 03:08 PM
Jagicon
Jul 6, 2022 03:51 PM
dancemom
Mar 14, 2022 09:34 AM
bobhoff
Sep 29, 2018 08:14 AM
Lommi
Jul 8, 2017 01:52 PM
